El Lobo 6" Mini Motor Bike
Frank the Tank
My fuel shut off is in a different location. Didn't want to spend money to be redundant. I'm great at being redunandant for free.
Made just for me!
http://www.ebay.com/itm/232514389133
This seat will fit on numerous minibike frames is approximately 18 inches long 7 inches wide in the back and 4 inches in the front, overall height in the back is 5 inches and 3 1/2 inches in the front
The 4th pic isn't the same seat. Hmmmm???? Why even add the false picture?
The first seat I saw was 14" and $35, Then it was $55. He told me same price for the one 18" X 7" and extra $20 for 18"X8" because his foam was only 7" wide. Made my seat 18" X 7" for $75 and the one I originally saw for $35 is now $65. All had additional $12 SHIPPING.
I guess a bit of GAB has gone to his head and now his prices are inflating.
Kick Stand
I think these are the same????
8" hypotenuse? 6" Vertical from mounting location to ground??
http://www.ebay.com/itm/291513568167
Kick Stand (8 inch) for 33cc, 43cc, 49cc 2-stroke Stand Up Gas scooters, X7 bike
http://www.ebay.com/itm/271826184587
Gas Scooter Kick Stand Part Mini Chopper 49cc 43cc Pocket Bike E200 X7 Mta1 Mta2
Specification:
Fits many applications
The kick stand is 6 inches top to bottom
Fits electric/gas scooters and pocketbikes
Quick and Easy to Install
I was unaware that I couldn't use White Teflon tape for fuel fittings. Apparently it is illegal in the state of Washington.
https://www.youtube.com/watch?v=Kir7gyjsIoQ
https://www.oreillyauto.com/detail/...high-temperature-thread-sealant/59214/4610193
Permatex high-temperature thread sealant is an OEM-specified product designed to lock and seal threaded fittings on a range of applications. It prevents leakage from vibration, temperature cycling, and extreme pressures—and it won't shred or tear like Teflon® tape. This high-temperature thread sealant is exclusively formulated to withstand up to 10,000 psi for fast, responsive curing on metal, tapered pipe thread fittings. It contains PTFE (polytetrafluoroethylene, also known as Teflon®), a material with good antifriction properties and high resistance to chemicals and harsh environments. The sealant is not intended for use on plastic piping.
I didn't like the bolt heads behind the seat... so no more bolts.
Waiting on paint.
I test fit the 7" Driven Pulley with the Comet 203591 belt.
I measured my shafts to be 6-11/16" apart. That belt is for 6-13/16" to 6-7/8" pulley spacing. I expected the belt to be long. Proper length should give 1/8" to 3/16" pinch and pull clearance. My pulleys are 1/8" to 3/16" too close for the belt. So I expected 0.250" to 0.375" pinch and pull clearance. It measured ~0.3125".
Might try to Slot the mounting holes to take up 1/8" to 3/16" of the extra slack. Or maybe put the stock springs/weights in the driver? Belt slack = higher RPM engagement?
Started slotting the holes in the TC back plate.
