Smoking 10hp tecumseh
mark123
Prince Edward Island, Canada
Our 10 hp tecumseh spits oil out of rubber crankcase vent and burns oil . Are these engines worth fixing, would honing and new rings solve the problem? It starts and idles/runs fine.
Staff Murderator
Any engine is worth rebuilding if the cost and effort is less than a new one...and especially if it is something you can enjoy.
Maybe the crankcase vent is toast?
Tear it down and inspect
Check cylinder for scoring
Measure piston ring end clearance...
mark123
I removed crankcase vent and cleaned it up. It simply is just a 90 degree hose open all the way through, no 1 way valve or anything. There is some mesh material behind the cover then a metal plate with some holes in it. Is this the way it should be. Also I checked compression, only 85 psi with electric starter and throttle wide open. Is there a decompression mechanism on this similar to Hondas/clones that would give false reading? Starts instantly, idles perfect....I wouldn't expect that with low compression.
Yes
Yes
Tecumsehs biggest downfall was their carbs; great engines, rubbish carbs; if you can source a rebuild kit, I'd take that path... with a new carb...
Staff Murderator
What 10 hp engine is it? Model number and designation, please. Too much conjecture going on here without solid facts.
Is it a flathead or OHV engine?
You need to pull the head and have a look at your cylinder wall--if it's scored badly, you're likely getting blowby--engine oil getting past the rings and into the combustion chamber.
You could have a blown head gasket.
Your PCV/Breather valve could be blown too, or clogged.
Hey how about some pics? Or would you prefer to keep us in the dark....:rolleyes:
mark123
It is a 10 hp "power sport" tecumseh flat head. I took pcv valve out and disassembled/cleaned it. Little bit of smoke pulsing out of vent tube. If I open oil filler there is smoke pulsing out of it as well. Other than the oil spitting it starts, idles and runs perfect.
KartFab
I fixed mine up enough to sell it for $250. Worth fixing to get rid of in my opinion, not to keep. it had that same issue, which can also be worn valves/guides, or even the little drain hole in the vent compartment being clogged up. It was just a big pain in the butt, so i sold it.
mark123
I just drilled drain holes in crankcase vent a bit larger as suggested by many YouTube videos. Seems to have helped, not spitting anymore. There are tons of videos on there regarding this problem.
