Simple/low-cost Electric go kart conversion
I wasn't happy with the return action of the pedal actuated thumb throttle :ack2:
Will tinker with it & adjust later
Here is another idea
Just mount the thumb throttle on the steering wheel
...with a piece of pipe & a small U-bolt :thumbsup:
Time for some testin' :thumbsup:
But, wait
If were gonna gather some data
We gotta get our meter hooked up
So,
I mounted the shunt onto a plastic base
...strapped it to the bat trees
...hooked the side labeled "battery" of the shunt to the negative (-) terminal of the bat tree pak
...hooked the negative battery cable (formerly went to bat pak negative) to the side of the shunt labeled "motor"
...hooked the meter lead wire to the positive (+) wire going into the motor
Yup!
Now were ready :thumbsup:
https://www.youtube.com/watch?v=1_9XMrJohm8
Next,
Were gonna step it up a bit :thumbsup:
Were gonna jump up to a MY1020 48V 1,000W brushed DC motor
It's rated current is 26.7 amps & it is speed rated at 3,000 rpm's
I had to do some adjusting, the sprocket was off about 1/4"
https://www.youtube.com/watch?v=ZxFo0T8Upm0
Test run was fun :thumbsup:
This 48V 1,000W motor is very perky/torquey.
It zips to 10 mph like quick
It moves right along & seems to transverse grass as well as it does pavement.
With this set up it speed tops out at just under 15 mph :2guns:
The meter showed that it drew ~25A at take off and averaged ~8A most of the ride.
https://www.youtube.com/watch?v=AxKkIaE2feY
Did the kart come with that axle sprocket?
Yup, looks like the factory sprocket that's been on there for years
It has an 84 tooth axle sprocket & a 10 tooth motor sprocket for an 8.4:1 ratio
Very torquey (if that's even a word) :thumbsup:
---------- Post added at 11:01 PM ---------- Previous post was at 10:36 PM ----------
Well, someone seems to be impressed with what we are doing :thumbsup:
This message was left on the 48V 1,000W test drive video
Awsome!. This is Mike from Alfa Wheels. Please visit my ebay store and mention this video, I will give you a 10% discount for any item not already discounted. http://stores.ebay.com/alfawheels1.
Clean, powerful & discounts :cheers2:
alim
I've seen their ads on eBay, they have really great prices on motors. Based out of Florida.
alim
Lol I think I know my way around your neighbourhood almost as well as you do :)
I mounted the Boma 48V 1,800W brushless motor & controller on e-Lemon-aid.
I made a terminal cover/pouch to help make a safer kart :thumbsup:
It will cover up the open terminals on the motor terminal connection port & I can tuck the other plugs in there also to help protect our other connections too.
The data seemed to be close to the 48V 1,000W brushed motor
avg amp draw: 8A
max amp draw: 29A
top speed ~15 mph
https://www.youtube.com/watch?v=3yzOS4cE424
Hold the presses!
"This just in" New information
A message has been left on one of the e-Lemon-aid videos that says:
"The diagram leaves out the "stalls" wiring which is important as it sets the RPM of the motor. If its not connected it runs at middle speed and not at its full RPM."
So, after doing more research, it seems that the "stalls" plug is for a (3) speed switch
If you connect the black & blue wires you get low speed ~2,680 rpm's
If nothing is hooked (like I have it now) it runs at med speed ~3,450 rpm's
& if you connect the black & green wires the motor runs at it's highest speed ~4,150 :wai:
Yup! :thumbsup:
Ima doin' some testin' tomorrow :2guns:
Stay tuned :cheers2:
Well, we have another translation
..."stalls" means (3) speed switch :thumbsup:
So, if you want to have full speed always available
...just connect the green & the black wires
But, to make this feature fully functional
...you will need an on/off/on switch
https://www.youtube.com/watch?v=V6u8LLgIAgc
