I picked up a yerf dog that had a seized 6.5 hp Tecumseh engine. I bought the harbor freight 6.5 predator engine. I have a couple of issues. The throttle doesn't really have a return spring on it but that is not a big deal. I can buy a spring, and attach it wherever I think. The big question is the old engine is 3/8" longer on the output shaft. I need to keep the spacer on the engine side of the clutch so the the clutch pulley lines up. That only leaves me with 3/8" of shaft left for the outer part of the clutch. The keyway works. The old engine only used 3/4" shaft. Is it enough? I cannot move the sprocket on the axle . Advise please. Thanks!!
