I think I'm ready to do my first engine build, was wondering if I could get a little guidance and direction along the way? I know there is all kinds of info on this forum about modifying the predator engine, and I've tried to read up as much as I can to keep the old questions limited.
I bought a hemi head predator last night after returning their new earthquake impact, that I was not happy with. The goal for the build is to get as much torque as I can out of this thing. I'm not racing or anything like that so shooting for 8000+ rpm isn't the goal for me. Has anybody built up a predator with torque being the main goal? What cams should I be looking at for this idea in mind?
If torque is your main goal, perhaps a camshaft with less than 8000+ target RPM would be more ideal. A cam designed for 8000+ RPM might not have great performance lower in the powerband. If optimized for 8000 RPM, it may not even run at 2000 RPM.
Sorry I read that wrong
My Black Mamba Jr cam was advertised as the "Ultimate Torque Cam". I had 3000 RPM clutch engagement and pulled to 7000 RPM.
My new cam is also for serious torque.
Camshaft, 285-0211: 7000 RPM. 11.0 to 1 compression or more. 26+ lb Springs Required, Small track cam for serious torque
Go to NR's site. Look at their camshafts. Their descriptions are really good. Will say Torque Cam, or Wide Power Curve, or Gets you off the corner,.... Some will say excellent mid range.. Or will say Small Track.
Most of these cams are racing cams tho. So most cams described as low RPM, High torque, will still spin faster than stock cams and may require a higher clutch stall.
Some will say for winching and marine applications. Those are for the lowest RPMs. Some will say large track. Those are highest RPMs.
It will also say what springs and Compression Ratio is needed.
I try to see how fast my gear ratio and tires will take me based off of engine RPM and pick a cam to get me to my desired speed.
For example, on my current build... I wanted 60 mph.
13" tires, 4.5:1 Gear Ratio (with TC)
7000 Engine RPM = 60 mph
So I picked a "Torque" Cam that will spin up to 7000 RPM. It should spin a bit faster. I think it should turn 7500 on this project when all said and done.
---------- Post added at 08:48 AM ---------- Previous post was at 08:43 AM ----------
An example of different cams from the 252 series from NR
252 SERIES- Approx .252 lift and 230 degrees duration (at .050).
Welded and ground cam provides significant power improvements over stock cam. Works best with mild motors using bored OEM or aftermarket carbs. Cam is BOLT IN and does not require block modifications yet keeps close to stock base circle to maintain correct valve train geometry. 26lb to 37lb springs should be used. Great with 1.3 rockers. Our number one seller.
Options:
Camshaft, 252-0207: SPECIAL HIGH TORQUE GRIND FOR SMALL TRACKS, 6000 rpm, 22 lb Springs Required, 26 recommended. 10 to 1 Compression or higher recommend, however it will work with lower compression ratios. This is one of the best choices for low end power, esp. on small dirt tracks with heavy drivers. (Oval Track)
Camshaft, 252-0211: Same as 0207, for Road Race, Wide Powerband applications (GX200, 6.5 Chinese OHVs, and Predators ONLY) Camshaft, 252-0607: All around grind for medium to large tracks. 7000 rpm, 26 lb Springs required recommended. 10 to 1 compression or lower. Great for Marine and Winch applications
Camshaft, 252-0607: Oval Track Grind, High RPM applications, 7500 rpm Max (GX200, 6.5 Chinese OHVs, and Predators ONLY)
Camshaft, 252-0611: Same as 0607, for Road Race, Wide Powerband applications (GX200, 6.5 Chinese OHVs, and Predators ONLY). Also recommended for Mini-Bikes
Camshaft, 252-1007 (120 ONLY): High RPM Grind for Large tracks. 8500+ rpm, 26 lb Springs required 11 to 1 Compression or higher*
Marine and winch board applications work best with 252 0211
Mini-Bikes work best with 252 0611
---------- Post added at 08:55 AM ---------- Previous post was at 08:48 AM ----------
Search for posts by bob58o. But make sure you're sitting in a comfortable chair.
What you thought I wouldn't be all over this one? LOL
These are the posts I come here for. I get to play engine builder with somebody else's money. Even if it only gets built in my head.
---------- Post added at 09:00 AM ---------- Previous post was at 08:55 AM ----------
And I read too quickly. I see you are NOT trying to turn 8000 RPM, so sorry about that.
