well i have a go kart frame but a blown engine go figure lol well the frame has been siting in my shed for about 2 years and well i have a tractor that has a 11.5 hp vertical engine on it (not sure of the brand) well anyway the go kart had a belt clutch that tightens when you hit the gas and the belt goes to a slighty bigger pulley and then is connected to a chain and then runs to the wheels not sure how many teeth is each ill get that tomorow and post it. ok and well all of this is horrizontal and the engine is vertical and i dont think i can turn it becuase of the carb and dont have any others so what i was thinking was mounting the engine in the front and run the belt on the pully like sopose like a tractor but twist it and hook it on a horrizontal pully like in the middle of the gokart and have it attached to a shaft and then to the belt clutch and then so forth to the tires. any other ideas you guys might have? and or what size pullys should i use etc.
sorry if so much to read lol
