Tire tread
Staff Murderator
The best, all-around, generic tread is.... TURF SAVER!
I think it was originally designed by Carlisle.
Look at them purty chevrons on the tire...
Does well on pavement too, without wearing too severely.
esfoder
Concrete Head
Eastern Oregon
This times 2. More Chevron's than a master chief.
Dusty
I've always felt that Turf Savers never grip enough on anything they are on...lawn equipment wise and they still tear up the turf quite nicely. Knobby tired will get you going nicely on dirt and grass, without killing it bad.
anickode
S.E. Michigan
Deep lug v-bar ag tires work pretty well on fancy professionally manicured lawns, especially on a solid axle kart with a huge engine.
One thing to consider IS how your kart is going to turn. With a solid axle, you have to allow for some tire slip so your kart will turn. If they grab the ground too well, your steering response will be crap. Drifting is also fun. Too much grip, and you can't drift.
The turf saver is a good all-around tire for running on mixed surfaces. It won't COMPLETELY annihilate a lawn, it won't wear out in 2 hours running on asphalt, and it's still got enough traction on dirt and gravel to be useful.
mustng87
cincinnati, ohio
oooooooooooooh!
A tire tread thread!
I loves a good tire tread thread! :D
:funnypost:
---------- Post added at 09:42 AM ---------- Previous post was at 09:41 AM ----------
Luckily this cart is not a solid axle...
anickode
S.E. Michigan
:funnypost:
One wheel drive? Doesn't matter what tires you put on it, it's not going to be very good on grass or off road, unfortunately. A live axle conversion would be the only real way to keep it from spinning that tire everywhere you go. That's why they have the nickname "one wheel peel"
If it's got a live axle with a diff, then some good knobbies could make a significant difference.
