Help... buggy stalling around corners
Chrisvdw
Chris
South africa polokwane
I have this 250cc dune buggy, its a bucket of fun bit recently its been acting up it... when I try to drift around a corner it just starts to stall like im swithing it off , it then gains traction again and revs back up, it also does it at high speed over bumps, I have tried everything I know but I dont know anymore
Zombient
Junkyard Derelict
Waco, Texas
This might be a stretch, but I've had it where the chain was so tight, it would kill the engine by putting it in a bind.
Also could may be a sticky float in the carb? Just throwing things out there.
Chrisvdw
Chris
Have you removed or detached the low oil sensor?
Im not sure it has one..
---------- Post added at 08:25 AM ---------- Previous post was at 08:24 AM ----------
Or made sure there's enough oil in it?
If it's just started doing this recently, you might find you're low on oil.
Actually last I checked it was a little over filled I dont supose that could be the problem?
---------- Post added at 08:27 AM ---------- Previous post was at 08:25 AM ----------
It could be a sticky float tho ill remove the carb tomorrow and clean it.... what difference would a better carb do for performance?
---------- Post added at 08:30 AM ---------- Previous post was at 08:27 AM ----------
I had this happen when my muffler bearings started to wear. :D
:roflol: maybe, I just recently replaced the blinker fluild , I accidentally spilled some on my dog... the poor thing couldnt stop blinking for 2 hours :thumbsup:
Chrisvdw
Chris
Thats not a clone motor... It looks like a GY6 with a reverse box....
I think its a clone... it doesnt have a name on it... heck the buggy doesn't even have one...some sort of Chinese knockoff... lol
---------- Post added at 02:02 PM ---------- Previous post was at 01:59 PM ----------
It has enough power but its a little unresponsive... so if I could have it more responsive it would be a pleasure to drive
In essences yes a clone.... They all are...
Typically when one refers to a clone here... A gx200 type clone... HF pred 212 or any standard 195cc 6.5hp motor...
Bubba_Z
Bubba_Z
Western NC
Chris, your not crazy, the cut off is real. This one sparked my interest due to my kart showing the same symptoms. Not in corners ( I can do doughnuts for hours) but with bumps/hard slams on the motor. Y'all have seen the 460, every time I go up the hill on my gravel road the motor cuts out like its turned off for a split second. The hill is full of 4"-6" bumps and is not smooth at all. The motor seems to do exactly what Chris is talking about. I am full throttle but the motor cuts out) And trust me, I have no oil sensor. It "feels" like it is electronic....like somehow bouncing the motor makes it cut out. It comes back in a half second but I feel it/hear it dropping. In all seriousness what can make a motor (any motor) cut out buy simply slamming it up and down like a jack hammer?
Bbqjoe
Banned
Location, Location
I don't know if this might be your problem or not, but I have a buggy that developed a crack in the frame.
Whenever I hit a large enough bump, the frame flexed enough to affect the throttle cable.
It made it feel like it was cutting out.
Chrisvdw
Chris
I dont think its the same... last i checked the frame was perfectly fine... but ons strange thing that i have noticed it that it only happens at full throttle over bumps and around corners...but if i floor it before the bump and go half throttle through it it acts completely normal... im betting its something to do with the carb.... once i get time im going to rebuild the carb.... hopefully it helps...because it really isnt good for my ego when someone is watching and i try to drift but it bogs down... makes me look inexperienced... :bannana: :bannana:
