Will this B&S engine work?
drecon
KCMO
I'm having trouble finding much info about the particular engine that came on my cart. What little I have found seems like this engine was used a lot on tillers which makes the throttle linkage a bit of a fiasco since it was designed to be ran basically WFO all the time. Just not seeing them on karts much. Will this engine work ok for a kart? Or will it not really be that great in the long run?
Another problem I have is of course the fuel tank hitting the seat. I'm thinking of making some brackets to bolt to the stock mounting holes that lift it up an inch or so and back a few inches but with the oval air filter setup it has the filter housing is in the way. Is it possible to run a pod style air filter on this engine? What do I need to do so if its possible? And then what do I do with the choke setup and crank vent hose?
I'm having a hard time figuring out the choke and throttle controls and getting it running right.
B&S
900 Series
206cc
Model# 122002 0394
Staff Murderator
I think I have the same series engine out in the garage and it should be fairly easy to add a suitable throttle setup AND a pod filter with the proper adapter.
Most kart engines are powered by repurposed 'industrial' engines for roto-tillers and so forth so you should have no major issues.
Relocating the gas tank is very feasible too.
EDIT: this air filter adapter will fit the stock carburetor...
http://www.bmikarts.com/Air-Filter-adapter-for-Tecumseh-Briggs-OHV-Engine_p_463.html
drecon
KCMO
Thanks for the link! More questions though..
What do I do with the crank case vent? Vent to atmosphere, or does it need hooked in somehow?
I would assume that if I pull the plastic intake pipe/air filter housing base off I can just bolt this adapter to the carb, figure out the crank case vent and call it a day? Do these carbs require any rejetting or anything after modifying the intake or exhaust?
Then I will have to address the choke lever. Right now the plastic lever wraps around in a semi circle from the back side of the carb where it connects, to the front and through the slot in the filter housing. With the housing removed I'll have a goofy looking half circle lever sticking out into nowhere. Is there a stock small lever from another model that can be swapped to tuck this in on that back side? Or maybe I will have to make my own?
On another note I don't understand how the choke and throttle work on this thing. The choke has 4 or 5 detents it clicks into as you move the lever. Why? I get full choke, half choke, no choke. But what are the other positions for? And when I cold start the engine with the choke and move it through the detents as it warms up, I get to half choke I can't go anymore without bogging the engine down and killing it. I can never get all the way to no choke. She runs like crazy up till that point then the next detent boggs and kills it..??
Staff Murderator
What do I do with the crank case vent?...
I would assume that if I pull the plastic intake pipe/air filter housing base off I can just bolt this adapter to the carb, figure out the crank case vent and call it a day? ...
Then I will have to address the choke lever....
On another note I don't understand how the choke and throttle work on this thing....
1) You can purchase a small catch can or a valve cover vent from an auto could work, otherwise see if you can vent the crankcase gases back into the carburetor somehow. Those pulses must add some efficiency into the motor you know?
2) Call it a day pretty much. But always be checking your spark plug anyway, for lean or too-rich conditions especially after these changes are made. Ascertain that you are on the rich side of lean as always.
3) I don't know about goofy looking. These aren't beautiful engines like the old flatheads. SO much hardware and parts and housings. I'd say as long as it's functional and works, go with it.
4) There is such a thing as running on half choke and varying degrees thereof. Especially in cold climates, warming up an engine sometimes requires opening the choke gradually. My Honda dirtbike is the same way--very cold blooded and it has two detents on the choke lever; full and half.
drecon
KCMO
Thanks for the help guys. I'll order one of those adapter plates and a pod filter and give it a go.
I was looking the throttle setup over tonight and I'm starting to wonder if it was running WFO because of how the linkages were setup. I only let it run for a few minutes while everything was all hooked up before we stripped everything down. This thing has a very short throw from idle to WFO. That could be an issue when its all hooked up. kind of an on or off only pedal I'm thinking.
Staff Murderator
...This thing has a very short throw from idle to WFO. That could be an issue when its all hooked up. kind of an on or off only pedal I'm thinking.
I honestly don't know this engine very well so if you say it has a short throw on the throttle, there's probably truth in it.
However I am fairly certain you're talking about the governor linkage which is shown in your photo.
If the governor linkage is bypassed, you have roughly 90° on the throttle butterfly with a direct linkage but it's on a small scale.
drecon
KCMO
The governor linkage is in place on this one. I just meant throttle cable engagement via the pedal. It seems like it will be pretty short, but this is my first kart so they may all be that way. I was mocking up a connection point on the governor arm to see how I wanted to connect the cable. (I'm guessing that is the best connection point on these?) when I did that and moved the governor arm through its travel with the proposed throttle cable connected it seemed like about an inch of cable movement was all there was from idle to WFO. Again this may be normal and Im just not used to that.
On a related note I cut the end off of the throttle cable that the previous owner was using as it was fraying out and had broken strands and held together with sheet rock screws. So now at the engine side of the cable its just a bare wire. Is there some type of cable end I can get that will allow me to connect it to the governor arm (drilling a hole) and tighten down the cable at the same time? I think I'm going to route the cable differently than how it came.
The pink circle is the cable end I cut off. The green is how I am thinking of routing the cable in. The orange dot is roughly where I am thinking to attach to the governor arm. The original "throttle" lever stamped with a letter "A" on it would be removed along with the grey spring connecting it to the governor arm. With the return spring on the governor arm that pulls it back to idle and this proposed cable setup the original A stamped throttle lever & spring wouldn't be needed anymore. I plan on connecting a kill switch so that connection wouldn't be needed either which makes the original throttle lever unnecessary. ??
anickode
S.E. Michigan
Attaching your throttle cable to the governor arm completely defeats the purpose of the governor. "Proper" cable attachment should be through the throttle lever. This transfers your pull through a spring, which pulls on the governor arm. This opens the throttle, speeding up the engine. As the engine speed increases, the governor exerts more resistance against the spring, and will reduce the throttle to maintain the RPM your pedal position is calling for.
If you want to keep the governor active, your throttle cable needs to attach to the factory throttle arm. Probably to that hole provided in the handle, just outside the faceplate. There's probably a place to mount a retainer clip on the faceplate as well. This will also correct your "really short throttle travel" issue. Then simply loosen the nut on the throttle arm a bit so the spring washers don't hold it in place. Might need to add an extra spring for throttle return.
Im guessing that other cable was put where it was to bypass the governor. Not the right way to do that. Especially not with a drywall screw.
