square tube (weld or bend)
I'm going to say cut and welded...
But over all depends on the design...
Do you have all the dies for crimping and properly bending a square tube...
I'm not an expert (but, I play one on TV)
I don't think square tube bends very well
Unless you got some big fancy equipment
So, I would go with welded
Go with a well thought out design (layout), good geometry (triangulation & such) & tight seams :thumbsup:
offroading73
no do not have any tools for bending. at one time i did have a decent shop but had to sell everything. now trying to get something going again but this time on a much tighter budget.
never have done any kind of tube bending. other than conduit.
Atlanta, GA
Years ago I read that tubing it always stronger when it is straight. This is a question a person could definitely GAB on.
anickode
S.E. Michigan
It all depends on the weld too.
If you do proper prep and weld it correctly with full penetration, that is your best option. If you just butt the seams tight together and sling some bird poop over it, you would be better off bending.
Square tube will not bend without the inside and outside radius buckling, so asthetically, cut and weld is better.
unbent tube is the strongest for sure..
if a welded or bent tube is stronger depends on many different aspects.
was it a cold deformation bent, is it well done or kinked,
what angle, what radius for what material,
was the stress reliefed or not.
how good is the weld, how much heat and has itaffected the integrety of the material ?
If so by how much....
In the end, you can always say "it never breaks at the weld" and call it good..
but when it fails right next to it... is it still caused by the weld or not? (sometimes it is...)
So IDK, I'd say there is no definitive answer to your question really.
kenworth85
Grouchy old man
Blanchard Oklahoma
I have built four karts with square tubing without any problems.I've done both weld and bend. Always cold bend I never bend over 90degree I think the outside of the bend gets to thin. I use 14 GA. only. I've used 3/4 and 1 inch and sometimes combine the two sizes, IMO it's easier for me to work than round. Don't waste your money on that bender,tried it and wasn't impressed. just my opinion only.
David Ham
Melbourne
big text,
tinamcjittles
ello m8
Allovau
Offroading, can you draw up your frame design and post a pic? I think this question depends on the application.. It should be true that tubing is stronger when welded square, because (if the welds are thick enough) there isn't any compression/expansion.
