briggs q
kc8oye
Byron, MI
not really kart related... but I have a briggs on a craftsman roto tiller.. that never seems to have the power it should when it encounters a heavy load.... is it possible to tweak the govenor/carb to squeeze a bit more power out of it?
clean the carb first and make sure the airfilter is clean;
also you might want to check the exhaust... we've seen rats nests in exhausts already.. but just carbon deposit and gunk can throttle the engine power down significantly.
While you're at it check that the transmission belt is in good working condition as well.
Fresh fuel, maybe even a fresh spark plug and you might find that good maintenance is worth more than halfhearted modification.
(which in fact require a full maintenance as well! so let's just start with maintenance only :D)
If you still think the engines power is less than it should be
the cylinder might be worn, or there's a small leak in the cylinder head gasket (loosing compression)
So check compression ratio, check valves to be clean and sealing properly, and if that does not solve your issue check the head from the inside.
IDK how old that tiller is, but esentially, if it hasn't seen several hundred hours of runtime so far.
I doubt it's worn (maybe carbon deposits preventing a valve from sealing *shrugs* but not much worse than such thing)
And if all maintenance leads to no improvement...
then you might want to consider a modification ..
more rpms is not a good idea on a tiller IMHO (balanced blades and such) sooo
I'd leave the governor untouched tbh (at best readjust it to stock specs in case it rattled loose in the past)
but maybe a high flow filter and exhaust and a slightly bigger jet to have a tab more oomph per stroke could do some good.
Maybe a thinner head gasket to improve compression a tiny bit
(and add just another ounce to the boxing glove)
but really no high speed power mods just the low down improvements. (IMHO!)
My lawn mower was sputtering real bad one day. Hard to restart after bag emptying. Thought for a second and while it was running I removed the air filter. Holy cow! It gained like 300 rpm and smoothed out!
Silly me, I forget that all it does is suck dust, kinda like your rototiller.
I'd go the simple maintenance route and report back.
pRoFiT
Can't buy it?, build it!
California
Yah picked up junk mower and it ran great first couple times. About third time using it wouldn't run. Thought no gas at first but it was full. After taking filter off, the thing was caked with dirt. I don't know how it ran at all. Put new filter in and started right up first pull. It was also a Briggs.
Amazing what some cleaning can do
kc8oye
Byron, MI
Sid.. its been like this from day one brand new
I always had assumed it had somthing to do with being a California-compliant engine.. my snow blower is the same way. My old 5hp tecumpseh powered blower could run circles around my kohler 6.5hp :(
---------- Post added at 12:21 AM ---------- Previous post was at 12:20 AM ----------
Btw.. just gave it its once every 10 years oil change..new okug, cleaned filter, replaced belt after a clutch malfunction destroyed the belt.
Staff Murderator
...Btw.. just gave it its once every 10 years oil change..new okug, cleaned filter, replaced belt after a clutch malfunction destroyed the belt.
Your maintenance regimen and frequency (especially) does not bode well.
Does it work better now or no?
