Engine sprocket loose... normal?
Going to go out on a limb and say no.
My axle sprocket hub is partially cracked and still holds pretty tight.
LyndhurstJohn
Lyndhurst, OH
My engine sprocket is splined and has a keeper that fits into a groove on the engine shaft. That keeper, though is thinner than the groove on the shaft so sprocket can move along the shaft. Do I just have a sprocket/shaft mismatch?
Scout
Nutjob
Indiana
Are you talking about the key and keyway? If so, no, it should all be tight together.
:useless::useless::useless:
If its on a cent clutch, there is a little play involved as the drum spins on a bushing.....
Scout
Nutjob
Indiana
Looks like a motorcycle engine/sprocket. How much play is there? A small amount (very very small) would be normal, the "washer" that's bolted on is what keeps it on.
LyndhurstJohn
Lyndhurst, OH
If you can ID make and model of this kart that would be great too... very similar to the Dongfang GK110
Scout
Nutjob
Indiana
Probably not normal, but take the sprocket off and inspect the lock ring ("washer") and groove.
I removed the chain from my go cart and was surprise in the play in the engine sprocket... is that normal?
That's not a go cart, nor a go kart.
That is a mass-produced Chinese buggy of many names. We typically deal with the go karts from days of yore. The 'old school' stuff and karts built from scratch in the same style.
I'd toss it out with a CL ad and go back to fishin' and ladderin'. :D
