Another Gearing question...
Improviser
whatever works
New Zealand
Hi all first post since joining the site... :)
Me and a mate of mine are building a Go-Kart as a class project at school. We've recently acquired A 6.5hp Honda Clone Motor oddly limited to 2500rpm instead of 3600rpm, now I'm trying to figure out gear ratios for it before we start collecting other parts.
The aim is to have it reach near 40kph/25mph with the stock engine, however I'm doubtful that will happen...
The rear tyres are going to be either 11" or 13", but I'm unsure if a 6:1 or 5:1 ratio would be better suited for the kart, which in theory is going to be simple and light.
My only viable options at this stage is to get a 12T Clutch and 70T sprocket to give me a 5.8:1 ratio (ideal for 11" tyres?), or pick up a 2:1 reduction box and get an axle sprocket made to suit for roughly the same price if not cheaper.
Is there any ideal ratio that I can go for at this stage? It is a bit hard to decide given I don't even have a rough idea on how heavy the kart will be once its finished...
Cheers :cornut:
Its going to be difficult to get 40 km per hour at 2500 RPM.
3600 RPM wtih 13" tires geared 5.8:1 should get you around 40 km/h.
5.8:1 is a good ratio for 13" tires. Its the 2500 RPM that is the issue.
Are you sure about that?
Maybe the Info you read was a typo error when translated from Chinese... It's odd because the specifications of serveral different brands of 6.5hp clone engines are: "Maximum Torque: 8.1 ft-lbs @ 2500 RPM", but the Governor on these engines are typically adjusted to allow them to rev higher to 3600 or 3800 RPM...
Do you have a link to the engine you bought?
Improviser
whatever works
New Zealand
What devices have used to determin the speed???
http://www.gokartsupply.com/mobile/ratios.htm I've been using this calculator for all my guessing and checking at either 2500 or 3600rpm, I just tried the one on this site and it gives me the same number so it can't be wrong
https://touch.trademe.co.nz/listing/view/1363839903
If the link doesn't work then yes it does says max torque of 10.9Nm/8ft-lbs at 2500rpm, so does this mean that the engine likely has a max rpm of 3600??
Cheers
Improviser
whatever works
New Zealand
Sweet that's good to know!
Have ended up going with 13" tyres and 14T to 43T ratio onto the 2:1 reduction box, should give me a ratio of 6.1:1 which will help a bit on hills etc
Thanks guys :auto:
keep in mind, that you MUST buy a wet clutch with 2:1 reduction,
NOT a 2:1 reduction box (which doesn't have a clutch)
Also make sure it fits your engine shaft!
Original Honda wet clutches only fit to short (50mm) metric 20mm diameter shafts IIRC,
most clones copied that.
You need a 3/4" shaft (19.05mm) version
So be sure to pick the correct one.
Improviser
whatever works
New Zealand
Hmmm will look at it tomorrow, I have to take it off another engine, a legitimate Honda GX200 out of an indoor kart (Rimo Evo6). I'll try fitting it to the one we got then before going any further.
Link to reduction box off Rimo: http://shop.rimo-germany.com/product_info.php?info=p1447_transmission-honda-gx-160-200.html
The engine we've got has a 3/4" that's 50mm long so it should fit but I guess I'll find out one way or another...
Will keep you posted on tomorrows events :)
Improviser
whatever works
New Zealand
Hmmm well nothing seemed to fit today...
Got the reduction box and pulled it apart in class to fit onto our engine, has got a wet clutch in it and everything else (I hope!)
Went to put it onto the engine and for some odd reason, the output shaft was a bit too long...
The original one on the Honda measured out to be just under 50mm as it should be, whereas our Chonda was something close to 60mm...
As quoted from the place we got it from "Shaft Length x Diameter : 45.5 x 19.05mm"
So not only is it a bit too long, the key didn't fit and the 'seat' (the thing that sits between the housing closest to the engine and the wet clutch arrangement had a bit of play in it when it was seated on the output shaft. Upon closer inspection, I could see that they've machined that end of the shaft differently between the two engines.
So I've ended up with the Honda Engine block as well (I dont know how to put up pictures yet..) After discussing with my father whose an engineer, it became apparent that the Honda is all in metric and the Chonda is done in imperial, hence the slight differences. The plan now is to make up a spacer between the Chonda and reduction box so it fits on, as well as machining up a sleeve and key to suit.
Don't!
return the clone engine for a refund, restore the Honda to it's former glory
(should be easy really.. they're nearly indestructible)
And you have all you need and want.
the clutch is likely made for a metric shaft, your imperial shaft clone cannot hold that.
there is NO premade shim to make em fit, you could make your own of course...
but why bother if you have a real deal proper Honda at hand?!
Improviser
whatever works
New Zealand
I haven't purchased the Honda just the reduction box off it, also it's missing a few parts around ,it but like I've said my fathers an engineer and can machine up a sleeve for the Chonda.
I'll have another look at the Honda and see what it needs, it's a spare parts engine for someone else in my class so I doubt I can get it off him.
Are there other clone motors that are metric?? Or were they done in imperial?
---------- Post added at 09:58 AM ---------- Previous post was at 09:57 AM ----------
Lets see some pics of your engine...
How do I post images?? It asks for a URL?
If you look above where it asks for a URL, you will see that you can upload pics directly
