karl
So 3hp briggs do not get much love.
This poor motor, about 4 years ago I shot at it with a .22 at WOT and killed it.
It sat outside with no gas or oil cap since then.
Today I decided to get it running.
The bullet hit between the head and block and broke the head gasket. So I hit it with a file and made a new gasket. Cleaned the points as it had no spark. A rough carb clean and it runs like a champ, no smoke or knock.
So, what does one do with a 3hp briggs? Make it go faster!
I want to see what this thing can do.
So I did some looking. The exhaust valve spring seems to be thicker then the intake, so to allow some more revs, you can install a exhaust spring on the intake valve.
My motor # is
80232 0721-04 79083103
Would #26826 be the right part # for an exhaust valve spring?
The more I look at it , I am thinking the valve springs for a 3hp and 5hp look the same. The cover is the same height. I will see when its apart but if so, I have a spare set of 18lbs springs so that would be cool.
Also I have read to file down the ez-spin bump on the intake lobe.
A tillston carb and straight pipe will be mated to her.
But we cant stop there, I am on the lookout for an aluminum push mower flywheel. That with an advance timing key ( yes I will build a scatter shield) and magnetron coil. Folks say there weaker then the cast iron flywheels so I will put that to the test. And last put not least polish the rod ,make the oil hole bigger, and fabricobble a better dipper. If anyone knows a nylon dipper for a 3hp that would be cool.
If it is still not enough some alternate fuels might be in order
And cant forget some paint, what color should it be? Anyway fun project hopefully. If I can beat a stock predator id be happy.
My motor # is
