3hp briggs build
karl
North east Ohio
So 3hp briggs do not get much love.
This poor motor, about 4 years ago I shot at it with a .22 at WOT and killed it.
It sat outside with no gas or oil cap since then.
Today I decided to get it running.
The bullet hit between the head and block and broke the head gasket. So I hit it with a file and made a new gasket. Cleaned the points as it had no spark. A rough carb clean and it runs like a champ, no smoke or knock.
So, what does one do with a 3hp briggs? Make it go faster!
I want to see what this thing can do.
So I did some looking. The exhaust valve spring seems to be thicker then the intake, so to allow some more revs, you can install a exhaust spring on the intake valve.
My motor # is
80232 0721-04 79083103
Would #26826 be the right part # for an exhaust valve spring?
The more I look at it , I am thinking the valve springs for a 3hp and 5hp look the same. The cover is the same height. I will see when its apart but if so, I have a spare set of 18lbs springs so that would be cool.
Also I have read to file down the ez-spin bump on the intake lobe.
A tillston carb and straight pipe will be mated to her.
But we cant stop there, I am on the lookout for an aluminum push mower flywheel. That with an advance timing key ( yes I will build a scatter shield) and magnetron coil. Folks say there weaker then the cast iron flywheels so I will put that to the test. And last put not least polish the rod ,make the oil hole bigger, and fabricobble a better dipper. If anyone knows a nylon dipper for a 3hp that would be cool.
If it is still not enough some alternate fuels might be in order
And cant forget some paint, what color should it be? Anyway fun project hopefully. If I can beat a stock predator id be happy.
72monte
Midwest
If I am right for more power you can remove the stock airbox/filter and buy a cone filter and use a zip tie and radiator hose for an intake, and if you go to go powersports you can buy a header, then you could either leave it or put a tractor supply muffler on it just to quiet it down some if you don't like the loud noise, and there are a couple of ways to file and Dremel the head for more flow and power, cool project by the way, I love them flatties
---------- Post added at 10:33 PM ---------- Previous post was at 10:24 PM ----------
I think a light beige would look great in my opinion, and don't forget about killing off those predators or you can anger people and put a Tecumseh sticker on her so predator owners will have a great look on their faces when you blow by 'em, ha flatheads are sure amazing, I have two, a 75 Tecumseh 10hp on an ariens snow thrower, and a 60's Briggs on an old snapper tiller it has 5hp and is about like yours, it will probably end up on a friend's manco sooner or later
karl
North east Ohio
Thanks for the advise, but I am ditching the stock carb and running a tillston hl-324 with a 2 7/16 cone filter.
Port work and eyebrow shave with a dremel is a must.
The pic is the setup I will run, same as my 5hp build.
Light beige would look cool, ill see what the local parts stores have in stock
karl
North east Ohio
It turns out 3 and 5hp briggs use the same valve springs. The springs on the left (well right because they are anti gravity springs) are new dyno cams 18lbs. The valve stem diameter , retainer, and distance from top to bottom of the valve chamber are all the same as a 5hp. So the 18lbs springs should allow some higher ripems.
karl
North east Ohio
I salvaged a thin piece of tapered aluminum pipe and made a maximum brap pipe. :cheers2:
ond
Russellville, Ky.
Nice work so far, and I love these old Briggs engines. I cut my teeth on a Briggs 3hp just about like the one you have.
Staff Murderator
Port work and eyebrow shave with a dremel is a must... Light beige would look cool, ill see what the local parts stores have in stock
Only on the exhaust port. Removing the casting flash and edges on the intake port is purportedly counterproductive as those defects help mix the fuel and air.
I think you ought to deck the block and eliminate the head gasket. :arf:
karl
North east Ohio
That is interesting, I have always heard you do not want to polish the intake , as fuel might fall out of suspension. But the Idea is to remove casting flashes and sharp edges for more flow. I dont think the fuel will have this problem going through a 1in manifold, then a sharp turn into the valve, with everything hot.
But who knows, I have been known to be wrong.
If I cant get the head milled, I might try that.
Staff Murderator
Did I word it correctly? Polish and port the exhaust only.
Turbulence and "artifacts" in the intake port are beneficial as you say.
karl
North east Ohio
Turbulence and "artifacts" in the intake port are beneficial to keep fuel in suspension in the air.
Fuel will not have this problem going through a 1in manifold (with a 45 degree turn), then a sharp turn into the valve, with everything hot. Heat and bends keep fuel in suspension.
Lots of turbulence is not needed.
So I ground out the casting flashes and rounded the sharp corners in the port, but left it all rough.
I am not disagreeing with you completely, but for this application I do not see the benefit.
On a 3hp briggs you cannot do a whole lot to the exhaust port as the only method of attaching an exhaust is the 1/2in npt port. I took down some rough areas and smoothed what I could out.
I also lapped the valves and installed the 18lbs springs.
But everybody can agree the best way to make more power is a coat of fresh paint.
Kansaskart
Lol I wish! 2.5hp with low compression here. 2 years later I was on a twin mac kart. Thats progress.
So, shot an engine? Elvis moment?? I dont feel so bad now thanks. Im curious...was beer involved?
karl
North east Ohio
Alcohol was a factor
You can see the damage below,
Anyway I polished up the rod and enlarged the oil hole.
As for the dipper we shall see what happens.
I decided not to bother with the easy spin, if anything I may add some extra valve lash.
On the lookout for a pushmower engine donor for the aluminium flywheel and magnetron coil , so I can put in a 4 degree advance key.
Staff Murderator
Guess you will be able to source or fab up an appropriate intake manifold for the Tilly?
Lookin good, nice that this thing took a shot to the block with little real damage.
Does this thing still have points ignition?
karl
North east Ohio
It has points, the issue with that is you cannot just move the flywheel to mess with timing. So I am looking for a coil to convert it over to magnetron.
Thanks,I will make a carb adapter.
karl
North east Ohio
Fabricobbled up the manifold and got the tillston ready.
I found a magnetron coil , lapped the flywheel to crank and eyeballed the timing advance to somewhere in the 4-7 degree range.
Made a .010 head gasket
Should make a brap or 3
I see.
Do you know what the stock timing is at? Ii know it's apples and oranges but I found a predator 301 is set to 24°btdc. It definitely woke it up just moving the timing to 32°.
You might be able to go a little further on what you guestimated. But I don't have much experience with flatties.
