What's wrong? Centrifugal clutch?
retepc4
Hi everyone!
I have a Yerf Dog 3203 go kart that takes off after about 5 seconds of starting the engine (see attached video). The engine starts up in one pull, but then takes off! From what I understand it is the centrifugal clutch, or the torque converter that has gone bad. if this is the case, where could I get the new parts. If not, what could be the issue? Thank you!
Staff Murderator
Clutch spring could be roasted, toasted and all but gone. That begs a question; has anyone run a clutch with the spring removed? Be like a clutch with 'free-floating' shoes...
:roflol:
Unless it a clutch similar to these... Then yes it won't really work...
Also Without the spring(s) it'll be basically a lockup clutch.
