Just couldnt resist.
weshole
Im sure you all can guess where this is going.
pRoFiT
Can't buy it?, build it!
California
Cant make the payments and its going back to the store you got it from? i've been there. i feel ya.
or
Down a steep cliff with you screaming all the way down? :thumbsup:
:popcorn: :popcorn: :popcorn: :popcorn:
take plenty of picture on your way down. :smiley_omg:
weshole
In all seriousness. I am debating over what throttle actuation I want. Twist throttle, thumb throttle, or brake handle style. Any input from experience?
Ebrownie
Western Montana
Brake handle will be easiest out of the three. But throttle hookup is literally one of the last things you need to worry about, it's so easy.
Joe-405
Enjoying New Projects
U.S.A.
A. The engine wont fit in that frame. It's the wrong style.
B. And most importantly you won't have anywhere for the sprocket to mount.
weshole
Ok so, it looks like you guys didnt catch what I was going to build. Maybe this will shed some light.
Btw, I am figuring out what throttle I am using as I have almost everything else to build this already. I cut up an existing kart to do this.
So, again I ask what throttle I should use. I have one so far that said the brake handle style. Anybody else have input? I am more concerned about making sure I had full throttle capabilities more than anything.
weshole
Did a lil mock up to see what needs changing.I now know that I need to change the head tube angle and raise the front frame slightly. Will be getting some new heavier gauge pipe to run from the head tube to the frame.
I use brake levers on my two bikes... I couldn't find any cheap twist throttle locally..
I used what I had...
What concerns me more is that you destroyed a perfectly good bike to make a drift trike..
I've been looking for one of those for a wile... They ain't cheap...
weshole
These are not hard to find. It was 180.00 for the bike used. They go for $220.00 new. The parts alone separately would have been far more. It was a economy bike as far as big tire bikes go. So, with the money spent, I get the forks, disc brake, caliper, tire/wheel. Plus I can use the rear tire/wheel, caliper and bracket should I decide to build another.
Want one even better than this one? Check this out.
https://www.walmart.com/ip/26-Mongo...Fat-Tire-Mountain-Bike-Navy-Blue-Red/29741123
TX7
Northeast Ohio
Looks good so far, drift trikes are the craze now. Is that a riding mower seat? I would need help getting up from that thing. ( I'm an old guy)
weshole
Its a padded tractor seat I pickup up from a local fleet supply. And it is hard to get up from. Im an older fella too.
