Tecumseh 6hp ohh60
AndrewJackson
Winchester VA
Hello all this is my first post to the forums although ive been lurking for a year now, I recently got a tecumseh 6hp ohh 60 engine to put on my go kart(it came with a minibike frame) i've gotten it apart now to clean it up and paint it, problem is i had to completely remove the governor as it was missing 4 teeth, what do i need to do besides a billet rod a non-plastic camshaft and valve springs to safely run this engine. any help much appreciated
Staff Murderator
Is that an OHV engine?
Theoretically you can run most of these engines up to an estimated 5,000-5,500 revs before the engine itself cannot run any faster on stock valve springs. It's called valve flutter/valve float. All the internals should be fine up to that point but expect accelerated engine wear.
Aside from all that, the flywheel is the usual concern for small industrial engines. Get a billet flywheel.
karl
North east Ohio
As for the rod this may fit ,
http://www.arcracing.com/6282-arc-billet-rod-tecumseh-5-5-ohv-3-484/
That is about all you can find for these. No one makes a billet flywheel.
A long time ago I found a camshaft but I cant find it anymore.
If you are concerned a hs50 steel cam fits them.
In stock configuration they are great motors even with the plastic cam.
I would suggest running the tecumseh stock with gov removed until you get bored , then get
a box stock , predator, or briggs flathead that have aftermarket support.
