Oil pump add on?
Staff Murderator
Nuff said. :D
Then show us... Quit with questions...
Why load a stupid question... If you know the answer....
IBTL...
Staff Murderator
Must be mind games. Ooh, he knows something we don't! He really showed us. :rolleyes:
Get one of those automatic chain oilers and fix it so that it drips into the turbo somehow and keeps the turbo bearings well lubricated.
Flyinhillbilly
The great cornholio
North West Arkansas
Journal bearing turbos require pressure to keep the bearings and shaft "floating". I think a belt driven pump would bf the best bet, although too much work for me.
karl
North east Ohio
speedy212/fr had dis shiz figured out contact him !
Anyway what kind of turbo do you think a 212 will spool?
EcoTrons electric pump is what some use. No need to tap the block, just get a barbed fitting that goes into the oil drain plug and thread it in. May need to add more oil into the engine, but not much. You will need a battery and/or a stator to help keep the battery charged.
I've got a battery on the bike now but does anyone make a stator with a battery charge output?
It's usually pull one out of a Kholer engine of some model. Usually 3 amp ones are A/C and not D/C so you'll need a regulator rectifier to not burn out the electronics. Usually it's fine for charging a battery, but I wouldn't risk damaging the pump. https://www.youtube.com/watch?v=r-W0KM2FO_0
Slo4sho
Fort Myers,Fl
My only concern is it won't work with a billet flywheel so would it be able to handle 8000 Rpms?
Flyinhillbilly
The great cornholio
North West Arkansas
You dont need to churn the ripems when you got that mad turbo torque. What implement of boost are you using?
In my experience the RPMS have a way of rapidly increasing on a turbo application at a pretty ridiculous rate, sometimes so much so that you have a hard time getting off the throttle fast enough.
