Having issues with setup
Spazzz
Can't seem to get it right....put a 13hp predator engine and brand new tav30 torque converter. I had to finish drilling out the low end hole...ive tried all the holes can get the cart to 50.3mph and climb anything in front of it...but can't get it to spin the tires. I don't care about top end would like to do donuts and drift. Manic 707xtk with 18inch tires...help please
Spazzz
10 and a 50 or 60 tooth...factory manco.....i ordered a 1inch 40series and got a tav30 with 1inch drive setup...
Spazzz
You have a mid and high hole and the low end one is partially drilled...trying to upload but having problems...
Ebrownie
Western Montana
Well if you want to spin the tires, you are going to need more torque. This can be achieved 2 ways; lower gear ratio or engine modifications.
Lower gear ratio is easier, but you will lose a lot of top end speed to get a low enough ratio. Lowering the ratio can be either changing the sprockets or putting smaller tires on. As a side note, putting smaller tires on will also give you less traction so it may be easier to spin the tires.
Modifying the engine will not be cheap, but then it will have the same top speed and pull harder on the bottom end.
Spazzz
Thought going from a modded 6.5hp to this would do it...also thought about tires..either smoother or smaller. Converter doesnt open quick enough for me I think..it goes strait to limiter and then climbs in speed(stays closed to long)...thanks for the input
Staff Murderator
If I order a 40 and got a 30 I'd return it and demand what I ordered.
Shrugs. He wants to spin the tires, mang. Just like they do in the moovies. Fast and the Furious!
It doesn't seem that he cares what they sent him. :rolleyes:
Ditch the silly Torq-A-Verter; those suck. They're power hogs. Get thee a manual clutch and never look back.
Rev it up, dump the clutch and spin tires. :sifone:
Spazzz
Took almost a month to get in...installed it and ran on it a few times when I dug into it I realized it was wrong...first time I've felt with these..called company and was told that since it was installed and used wasn't going to take it back,asked why I was sent that and they said that's there 40 series setup...
No fast and furious just want to play could care less about mph
Ebrownie
Western Montana
*couldn't care less. :D sorry, sometimes I impulsively correct peoples grammar.
Anyway, I agree with hellion. A torque converter robs a lot of horsepower because of the belt and sheaves. If you really want acceleration and breaking traction, get less grippy tires and get a manual clutch :thumbsup:
Although, I just remembered that 3D only makes a manual clutch for a 3/4" shaft... so you may be out of luck there, unless there is a 1" manual you can get somewhere.
I still would damand what I ordered. If the call a 30 a 40 then that's their mistake.
It might work but your pushing the hp limits of a 30. You might be buying belts alot.
Since you don't care for speed the up the back sprocket tooth count by like 10 or 15 teeth. That will spin em.
But which is it a 50 or 60 tooth. That's a big difference.
Spazzz
It's a 60 tooth..dont see any with more teeth unless I change my axle from hex to round.......company was auto express...was cheap 80$ so it is what it is just hoping to make it work some how
