Fabricobbling a kart
karl
North east Ohio
If anyone wants to play along at home I found an air filter adapter that will fit this carb.
Might be an clearance issue with the choke lever , but I have a grinder and I aint scurred.
http://www.bmikarts.com/Tillotson-314-Filter-Adapter_p_467.html
that carb won't work too well ..
and while it's a 6.5horse chainsaw it's intended for..
it's a two stroke with not even half the combustion volume you're dealing with on your flatty.
IDK.. 16 bucks might be worth a try.. I doubt it though tbh.
And yes, a very similar sized carb sits on many racing engines (all two strokes though for all I know )
I am glad that it works well, Imo mikuni carbs do not belong on a flathead. I ordered a few extras for future garbage.
Proven fact- This sticker makes pump gas 103 octane race fuel
Randy H
Road signs are about the only thing I will steal. I don't know why, but I just don't count those as doing wrong.
Sorry to be a judgemental bonehead. I've done some shameful things.
I've also had things stolen. At times it was life altering.
karl
North east Ohio
People that think conduit (emt), or water pipe is ok for karts scare me.
This frame has 3 runs of 1in thickwall tubing (not pipe)
In its defense I have rode it very hard and put on a predator with a marine grind cam, thin head gasket, and some other goods. And got airborne a few times.
In the green circle , I will cut out the tubing, insert steel rod and plug weld it, then add a top section to the frame, to make it twin beam. And some other improvements.
