How much compression on stock internals? GX200
Kleyny
Brisbane Australia
I had a quick search but couldn't find anything.
i have a GX200 with the governor removed ( keeping the revs to around 5000rpm), custom exhaust and upgraded filter.
I'm looking at fitting a GX160 head and a thin gasket.
I dont particularly want to upgrade the internals as parts here in Australia arent that cheap.
Am i safe enough to run with these specs with catastrophic rod failure?
I dont mind running hi octain gas.
Tanks
Neil
P.S man arent these things addictive :cheers2:
Any compression gain is gonna help.
I would say the head would fit but I would also play with clay to find out for sure. Wouldn't want the valve to kiss a piston.
Randy H
In addition to clearance issues, IMO it would be wise to cc the heads and calculate the static compression ratio. Knowing the dynamic compression ratio is important as well. There are calculators available online. Intake valve closing after bottom dead center, IVC ABDC, is common cam spec and is a big factor in determining DCR.
Typically higher performance cams have a later IVC ABDC. The intake valve closes later, so there is less stuff to compress. Therefore they have a higher required static compression ratio. I believe a good DCR number is 9:1.
With a stock cam you might achieve this at say 10:1 static compression ratio. A high performance cam might need 12:1.
there's a nice chart for compression ratios on gx200
using different gaskets, dished or flat top pistons
as well as milled or unmilled heads for all three the gx200(22cc) , gx160(18cc) and gx160-old style (14cc) head
basically all stock (dished, 22cc head, unmilled, 0.01 gasket) 7.7:1
all equal but 18cc head : 8.8:1
and 14cc head : 10.3:1
(all plus one for a decked block)
I'd attach the chart but it's 1kb too big for the forum soft..
I'll ask Robert to increase the limit ;)
Kleyny
Brisbane Australia
Thanks it would be nice to have that chart.
So I'm going to be around the 10-11:1 mark, would a factory cast alloy rod handle this at 5000rpm? The engine only has roughly 4hrs governed on in it.
Thanks
Neil
Flyinhillbilly
The great cornholio
North West Arkansas
I've ran a GX160 with a flat top, 14cc head and .009 head gasket on nitromethane with a stock rod. Personally I think it's rpm that kills them rather than compression. I wouldn't sweat it.
Kleyny
Brisbane Australia
Ok you took it two steps further than I'm going so its good to know.
From all the research I have done it seems RPMs are a killer in most things in these little motors hence the reason staying around the 5k rpm mark.
Now to sneak a purchase in without the minister of war and finance finding out.:p
Kleyny
Brisbane Australia
lol. Fortunately this one has been better than i could ever hope for. A lot of my friends think that she's faulty and very rare due to the fact there's no winging, doesnt shop for the sake of shopping and stands behind my life moto of the man who dies with the most toys wins. Hence the shed full of boats , 4x4s, go karts, motor bikes, campers.
She normally lets me do what I want when i want but I've been spending a fair bit on my toys lately.
Flyinhillbilly
The great cornholio
North West Arkansas
I watched my first man die at eight years old in our dining room. That has a way of driving home the fact that none of this really matters, all men are equal in the end.
To thine own self be true.
Kleyny
Brisbane Australia
This is true.
All i can say is man i'm havin some serious fun collecting and playing with all my toys.
Life is too short
Now back to finding 70 dollars for a new head.:cornut:
Neil
Flyinhillbilly
The great cornholio
North West Arkansas
I had a killer 14cc big valve head built with 36lb springs and stainless valves for $160. Pm me if you're serious and I can put you in contact with the guy that did it. He knows his stuff.
Randy H
FHB, curious what cam you were using. I doubt most guys here want to hear any talk of dynamic compression ratio, but it has to matter. If you don't figure it all out, is like a pig in a poke.
