This thing shall be one of my first vehicles with brakes, The drum and petal are mounted I need to make the cable happen.
Stickers make my kart go faster.
Anyway some might know the motor but anyway it has,
ARC billet rod
20lbs valve springs
Dyno Cams 95-4 cam (3500-6500 Rpm range)
.027 head gasket + Studs
ARC billet flywheel
Port work, eyebrows shaved
I just ordered a new carb and fuel pump because every bump the motor cuts out even with a new diaphragm. And it does not rev out like it should. Anyway ill cover that.
