Slo4sho
I've got a predator 212 hemi and it doesn't seem to turn the Rpms I think it should. I've tried jetting up and down but doesn't improve. Max rpm I've seen is about 6,700rpms. Motor is on a mini bike with gear ratio of 5.00. 14.5in tires, 75t axle gear, 15t clutch.
Mod list: Arc flywheel 8*, Arc billet rod, .010 head gasket, head shaved .030, 28lb valve springs, stainless valves, Arc J2227 carb, 140E tube, intake, exhaust, governer removed, custom gas tank, walbro fuel pump.
I'm out of ideas and scratching my head.
Thanks
Thanks
