big block gov mod for more rpm
Garryjav
joppa md
a few months ago i ran across a video showing how to mod the gov linkage on a big block engine to get a few more hundred rpm,well i can't find it now.
I have a powerland 420 on a big dingo with one of those cheap ebay tach I'm only getting 3390rpm
If your gonna play with the governor, know this.
It's been found that if you by pass the mechanism externally WITHOUT removing the internals, it will blow up.
If you bypass the mechanism but leave all the springs and levers, the internals seem to hang in there. I'm testing this theory now.
Third option is to move the spring to a different hole and raise the governor RPM range.
I have a BB Brigs on a Dingo and freewheeling can spin 6k but on the ground it seems to top out at around 4.5k. I gotta hit the brakes for the corners. This is also measured with a cheap induction type tach/hour meters.
My GPS speed is 40mph.
18" rears and 6.75:1
Garryjav
joppa md
Third option is to move the spring to a different t hole and raise the governor RPM range.
this is what i'm wanting to do and had found a video showing how but can't find it now
I know of the video you speak of but I can't remember who posted it.
If I remember take the spring on the long arm and move it toward the piviot.
Someone here is gonna pop in with a link soon.
Hang in there.
Garryjav
joppa md
yup thats the vid i was looking for. i thought it was done on a 8hp predator
i guess i'll play around with the springs on my pd420 and report what happens
Garryjav
joppa md
well i messed with it today, i could'nt get it to work like that vid says but i did tighten up the spring thats on the rod that goes to the carb and that got me to 3600
KartFab
Congrats, :wai:you are back to almost the same performance you could have had if you had not jacked with it in the first place.
Cutting corners won't get you very far, but if you want to get a great performance boost for about $70-$120 you could do the high flow intake, rejet the carb, direct link the throttle, remove governor, and install a high flow exhaust.
