Driven Clutch - Can I flip it?
ShapeShifter
Tinker Ninja
Vacaville, CA
I just bought a used kart I am going to fix up. This is a 420cc clone on a Manco XTK.
I need to align the belt and I have run out of room to slot the engine mount plate holes. I am wondering if I can just flip the driven clutch instead.
I have seen pictures of the driven clutch facing both directions on different karts. Is it that simple, or am I missing something.
If you get a reverse wound spring, then as far as i know you can flip it. You won't be able to do it just as it is. Wait for some more knowledgeable people though to chime in
well the spring installed IS a reverse wound one..
so you need the "normally" wound spring (red not yellow)
And then you can (in fact you should IMHO)
since inboard is the way to go with series 40 TCs;
outboard (as you have it right now) causes misalignment in the belt if you do not allow the driven to float
(and floating drivens opens another can of worms)
So yeah, go ahead and buy a series 40 spring (should be red must NOT be reverse wound!)
install it (keep in mind to preload it correctly) and flip the driven.
ShapeShifter
Tinker Ninja
Vacaville, CA
Thanks!
Can you take the bushing from behind the driver unit and making it closer the the block?
I believe that is the 1" output shaft, not a bushing.
Lots of work to do on this buggy. Notice the "weld" on the swing frame?
Looks like the end of the PTO shaft with a keyway like it is supposed to be but it also looks like the bolt has been broke off inside the PTO shaft.
Rust appears to be the only thing holding the driven unit on.
---------- Post added at 10:59 AM ---------- Previous post was at 10:54 AM ----------
I noticed in the first pic you posted, the driven unit has rust on the sheaves. I'm sure there are other spots that need work too but the TC need to be removed and cleaned properly to work again.
I'd go buy some PB blaster and soak everything and wait and soak and then start hammering it apart. Patience and knowing where to tap is the trick.
KartFab
Just as an FYI, that kart is really fun to drive :) suspension feels great. Could you take some pictures of the rear swing arm setup? I bought the same kart and a guy had modified the rear end so much that it make it have 2" of ground clearance. Going to be redoing it.
ShapeShifter
Tinker Ninja
Vacaville, CA
This may turn in to a full blown demolition job. I may need a whole new TC, if I don't ruin the crankshaft on the engine too......
---------- Post added at 08:41 PM ---------- Previous post was at 08:40 PM ----------
I started a build thread over here: http://www.diygokarts.com/vb/showthread.php?t=36079
There are a few pictures there.
