Locking a clutch?
clint357
Grand Rapids, MI
Hey, new guy here. I just bought a used "Green hornet" for my 6 and 9 year-old boys. The guy who had it before me had it setup to engage at a very high rpm and for the driven clutch to have almost no resistance so it would go into the highest gear as soon as pressure was applied. It was way too fast so I put a zinc weighted drive clutch on with a fairly light spring, but the top end was still too fast for my relatively small yard and young kids. I got the idea to lock the driven clutch and make it adjustable. Let me know if I messed anything up or if this is an ok idea. I just took it out, and it seems to stay nice and slow with lots of torque and I can easily adjust it as needed. I just want to make sure there are no ill effects on the kart. Thanks.
Ebrownie
Western Montana
Welcome! I am not sure, but the only thing I can think of is it may wear your belt faster. I guess just try it out and if you are shredding belts, then maybe try something else. I'm no expert though. Someone else might know more.
B.M.800
TheBeal.
Central PA
I would get a centrifugal clutch and a few sprockets to re-gear to whatever speed you want.
The 3 holes already on the TC are to adjust the spring pressure. Did you try that first? I can for see the new screws digging in to the aluminum from the force of the belt trying to get pulled into the pulley.
Also gonna effect the center to center distance with the belt tention being off.
Try it. Blow it up. Take pics. Prove me wrong.:cheers2:
Kleyny
Brisbane Australia
So what does your drive pulley do now you have stopped the driven pulley from expanding? Would it be better altering the drive clutch so it stops pulling the driven pulley apart?
As I rethink that as you mention, your right, what normally stops the driver? Mostly just the weights traveling their full distance.
Now if the driven stops and the driver is say only half way in its travel, it becomes a game of which is greater. The centrifugal force of the weights vs the tention of the belt. It's probally the belt gonna win and the weights are just left hanging in the middle.
I like to over analyze anyway.
Put it in action! Real world results are best anyways.:thumbsup:
JollyKarter
Texas
I don't remember who had it available, but there is a speed limiting driver pulley weight set out there. I think it is just a replacement weight set, and instead of smooth pins for the weights to move on as they expand, it the pins are threaded and have nuts so you can adjust how much the weights push apart and keep the driver pulley diameter small.
---------- Post added at 08:48 PM ---------- Previous post was at 08:44 PM ----------
http://www.gokartsupply.com/mobile/speedr.htm
JollyKarter
Texas
Honestly, you could probably convert one yourself...just use a tap and die set and thread the rods on your OEM weight set....
JollyKarter
Texas
If you pull the outer spring off, it seperates into 2 seperate weights, and there is a rod mounted to each one.
