karl
I am doing this for the coolness factor and the motor and pump was free so why not. The motor is a cool bore so it will not be missed. The smog pump is from a 80s gm 350. I made up some manifolds, and mounted up a gy6 carb I got from bmi karts for $1. I modified it for blow through operation. I blocked off the choke and the bowl is pressurized. Gas will be fed from a pulse pump off a lawn mower. I need to fabricate a bracket to mount the pump as pictured below. Then a hose and two clamps and we are boosting! I will mount a gauge somewhere. If this makes boost I will invest in a billet rod. I dont expect it to last very long but it will be fun. The true test will be throwing it on a minibike and drag racing a rotaderp powered mini, and a naturally aspirated 5hp briggs. Anyway it gives maximum bragging rights.
