gear ratio for hills
horror_fan
Bought the kart with a 60 tooth axle sprocket and a 12 tooth clutch sprocket.
I have an old 5HP raptor ( definitely wasn't putting down 5hp , I can go into details later).
I would take the kart around the neighbor hood ( many hills , and all considerable"steepness" ) and It would be slow but actually pick up decent speed half way up the hills.
Anyways Im thinking about lowering the gear ratio just a slight bit to get some speed on the hills.
Would this be a bad idea? Is the ratio I'm working with now pretty much optimal?
Thinking maybe buy a slightly smaller axle sprocket if i cant find a cheapish one.
Maybe trying to get it down to between ( 4.2-4.6 ) ? really have no idea about the difference it will make ( i just under stand the generally affect of lowering gear ) , I also bought a new clutch a few weeks ago as old was is getting ...old, its a 11 tooth. I may not use it because Im not sure how to install it lol embarrassing.
I guess the question would be, when lowering the gears ( 5 , 4.9 , 4.8 4.7 , 4.8 ... 3.4, 3.3), at what point will i loose the ability to drive it on flat land.
You have got it wrong. If you want to climb hills you need a lower gear ratio that what you have. You have 60/12 = 5:1. You are talking about getting a smaller axle sprocket. That will give you a "higher" gear ratio. Even though the number will be less than 5, it is called a higher ratio. What you need is a larger axle sprocket or a smaller clutch sprocket. This will hopefully give you something like 7:1, which is more ideal for hills. Your speed will suffer, but you will have more torque. It is all a trade off
Low gear=numerically higher.
High gear=numerically lower.
To help a lot, switch to a 30 series torque converter/CVT. That'll help with speed and help increase torque. A centrifugal clutch (assuming that's what you have) gives you only a static constant gear ratio, perfectly fine for either top end or low end grunt, not much in the middle. You'll want to put on at least keep your current gearing, drop to a 10 tooth on the clutch or CVT and/or get a 65 tooth or higher axle sprocket. These will help out a great deal for getting up hill.
horror_fan
Thanks !
Yeah.. after posting this thread, I was still reading things online on go kart gear ratios and started to sense I had it mixed up.
Anyways, might not be able to do a bigger axle sprocket b/c Its already pretty close to the ground ( if i'm remember correctly ) ...
What about changing both the sprocket sizes on the clutch & axle to get a smaller ratio & more torque ???
I think I want to try what 6.5:1 ratio will feel like ... Based off the feel it has now ( 5:1 ).
right now I have a max torque , which I think is a centrifugal clutch.
what do you mean by "grunt"?
Can you post pictures of the kart? Smaller sprocket at the clutch will help with a lower ratio. How large are the rear tires? That can help us determine what you need. 6.5:1 might be perfect.
horror_fan
okay ill try and get some pics up before the afternoon ends.
6 inch douglas chrome wheel on rear, not exactly sure what kart it is but the most similar i can find so far is the Yamaha r1 go kart
(just to give you and idea)
sprocket is a blue colored 60 tooth
i took the axle and front wheels off last night ... ill still post a picture tho.
horror_fan
just included the axle , i don't think the frame is relevant.
looks like the brake disc is bigger, so i definitely will have more room for 5 more teeth. or i can just get bigger rear wheels.
I can see why you said you have very little clearance. You'd probably want to go to a 10 tooth on the clutch or whatever you have now and then find a sprocket that'll still give you enough room to not worry about the chain catching the ground. That could be up to 65 tooth.
---------- Post added at 02:44 PM ---------- Previous post was at 02:44 PM ----------
Most places online will give the diameter of the sprocket, so that should help out a lot.
horror_fan
thanks i think that plan will work better since i need a new clutch for the engine anyways.
Would you know were to buy bigger spark plugs 14mm 1/2" long thread?
Also is there something i can install on the crank/PTO for adapting cutches? I bought a clutch recently it has no set screw, it only has a slot for a key stock ... and my crank/PTO shaft has no "slot" for the keystock...
Flyinhillbilly
The great cornholio
North West Arkansas
I'd like to see the frame, that axle and tires looks like what's on my kart and I run it at 4.83:1 and it's fast. You may simply have a clutch issue. Have you oiled the bushings?
tinamcjittles
ello m8
Allovau
Why would oiling the bushings help? (genuinely asking)
BTW, remember how speedy212 did that stupid 3.6:1 video? My kart runs 4:1 and the shoes are barely even worn!
Oh, and yeah Hillbilly's right, horror fan. You shouldn't need to mess with your ratio with wheels that small! You may want to consider modifying the engine for more woopow...
horror_fan
i have future plans to build the motor , but for right now im just replacing gas tank gasket, puting fresh fuel, replacing the plug and oil.
i also have to buy front wheels and some other stuff
and i thought for now a diff gear ratio would be fun ....
but i concluded ill buy a new clutch to lower the ratio , see if it makes much of a diff. stil will be fun regardless
plans build the motor will prob be for summer.
and as for oiling the bushings .. everything that i own with wheels (that i frequently use) is regularly oiled . so yes everything on my go kart is properly greased and oiled
Flyinhillbilly
The great cornholio
North West Arkansas
I ask because if the clutch bushings are binding then you will have a harder time getting it into the power range of the engine, plus it's about the easiest place you can start.
