First Build Need Opinions
Shadowbob700
North Carolina
I am a new member looking to start my first ground up build. I have grown up around motor sports, from dirtbikes, quads, go karts, etc. I currently build and modify motorcycles and have always wanted to build a buggy, like a Badland Buggy or something similar. Being that I do have kids and a family to feed, and will be starting college soon, I am looking to build a smaller buggy first, also that would give me experience in buggy building. So far the two main plans I have been interested in is the Spider Carts Arachnid, and the DiyDen Dirt Devil kart. I am looking for somewhere around 15hp, and top speed of 40mph or so. I am not against using a dirtbike motor or similar for a power source. My main concern is durability of the chassis. I don't want to have to baby the kart and cant say ive never had a go kart front end off the ground off road. If I were to use stronger tubing, and built the Dirt Devil, could it stand up to pretty heavy abuse offroad with 15 or so hp? Not completely jumping it by any means, but blasting through fields, trail riding, and sandy dune areas? Sorry for such a long post, just trying to be clear. Thanks in advance.
Shadowbob700
North Carolina
Thanks, definitely have been looking at different designs, would like to atleast base it around a plan to get started, then modify it as I go and find out what works.
That comes down to correct engineering which, you would think, has already been done by the designers...
It should stand up to that "abuse" already but, if you want to use "stronger tubing" go up a size or two; it's better to use larger thin wall material than small thick wall material; larger material adds strength, thick wall material adds weight...
Don't be, it's always better to offer info that be asked for it :thumbsup:
Shadowbob700
North Carolina
So I think I will be going with 1.5" square tubing with a .083 wall as its easy to find locally. Would that work alright? And what size axle would be good for an off-road kart? Think a 1" should hold up? I'm not a big guy, only 160lbs
.083" should be fine, it's 14 gauge. Just have proper bracing. 1" solid steel axle is a good choice. Sounds like you are choosing swing arm suspension for the rear end?
tinamcjittles
ello m8
Allovau
With good suspension you shouldn't need to over-build it too much, and if you do go with the bike motor then you have to use a CBR600... They're only like 115 horsies! nothin major
Post vids of the sweet jumps you take this thing on!
Flyinhillbilly
The great cornholio
North West Arkansas
