30 series torque converter problems.
Babb
Peg leg yard karter
Louisiana
I bought 6" driven off of Amazon but new belt rides up out of groove about 1/8th inch is it supposed to. It keeps creeping
Babb
Peg leg yard karter
Louisiana
The cart goes by itself slowly. And where the belt fits in the driven. Not a v Groove bc one side is flat.
---------- Post added at 03:16 PM ---------- Previous post was at 02:51 PM ----------
Thanks the diagram helps some
KartFab
The creeping could be because you got the wrong belt (measure center to center per the users manual), or because yourdrive unit is dirty, or. Ecause your engine is idling too high, or because your drive and driven aren't lined up.
Kentucky Boy
Bowling Green, KY
Could be idling to high causing it to want to take off. Could also have the wrong belt. Just research on here. Plenty of info and pics to help you out.
wpheinz
wpheinz
new Haven ct
I have a tav2 torque converter on a Coleman CT 200. When I lift it on a milk crate with no load to torque converter works as it should but when I ride it it doesn't go out of the lowest gear ratio the front pulley does not close what could be the issue?
The problem is your hijacking someone else's thread.
Please start your own. And post pics for the inmates to drool over.:thumbsup:
Bbqjoe
Banned
Location, Location
All these torque converters were made quite a few years ago, and sat in a warehouse for a really long time while some serious litigation was sorted out.
TC's have a shelf life, and these are all way past the expiration date.
:wink:
