Pred. 212 with mikuni 22 carb question??
SULLY_M
Southern California
Im starting a new project with a new predator 212cc ive purchased a header pipe, mikuni 22 carb and my question is if i keep the gov. What do i do with that clanky throttle/ gov spring bracket? If its easier ill remove the gov. but id rather not do that right away its not going to be a rocket kart just something for my son to learn/ enjoy
Bbqjoe
Banned
Location, Location
I'm not so sure there's a way to incorporate the governor with a mikuni.
I installed a mikuni 22 on one of my engines, and I just couldn't see a way.
Same here.
Not with out fabing a pull cable off the throttle/gov to pull the mikuini slide.
Doable but not easy.
I have been lucky so far leaving the gov and all the springs attached and just have a pedal to carb cable.
The gov "thinks" it's working.
Flyinhillbilly
The great cornholio
North West Arkansas
I've got the governer on my predator set at valve float and haven't had any problems yet. It's ran 10-12 hours so far pretty much wide open on a circle track. I think you'll be fine if you do it like WTR did his.
tinamcjittles
ello m8
Allovau
Outcry that looks like a blast! But those dogs... It's amazing that you drift at 30 though; and Kentucky guy I think it's for torque?
outcrydrummer
KART ART
Greensboro, NC
I don't see how you could use the Mikuni with the governor. Why not leave the stock setup on it? Why the Mikuni?
Valid point......responded to quick to this one. You would have a heck of a time keeping the governor and installing the mikuni.
I would ditch the governor and use that mikuni.
Kentucky that mikuni has a ton more throttle response and is just an overall better carb than the stock style carb. It hands down better than even the bored out reworked nr racing .650 stock style carb.
---------- Post added at 06:09 PM ---------- Previous post was at 06:07 PM ----------
Yeah my pit just wants to chase tires lol. Sometimes it can be a little aggravating getting her to stay back long enough for me to start moving LOL.
Putting a set of grooved tires on soon so I can get the kart to stick a little better so I can control when I want to drift and not drift. That should let me get up a little more speed too....probably 40ish MPH.
Kentucky Boy
Bowling Green, KY
Yes. I have a Mikuni on mine. It's a big improvement. If the kart is for a kid to learn on why mod it if you are not going to remove the governor?
