Predator Hemi valve spring upgrade
rickou812
North Florida - Tri-State Area
Looking for tips/advise on installing 26lb valve springs with automotive valve retainers and keepers (half locks).
Do to the way the valves are laid out in the hemi heads, not much room to work and I am not able to compress the 26lb springs far enough with one hand to get the half locks installed.
Which valve spring compressor tool have others had success with on these heads?
Any tips is appreciated.
Thanks,
Rick
LOL
I remember the frustration well.
The first time I installed 26lb springs with the split keepers it took me over 4 hours.
Now I can do it in 5 minutes.
The valve spring compressor tool I bought didn't fit. but it was a different type. One that only grabbed the spring (didn't hold the valve).
I had luck putting the head on my knee (valve face against my knee cap) and also on a table with a microfiber towel rolled up inside the chamber to hold the valve. I tried using both my thumbs to press on the spring with a pencil in my mouth to position the keepers.
I also tried the end of a box wrench, which made compressing the spring easier.
An extra set of hands is helpful. Like you hold this spring compressed while I position these keepers.
Once the valve is compressed, it is still a B to position the two parts of the keepers correctly.
Flyinhillbilly
The great cornholio
North West Arkansas
I haven't been into a hemi predator, but I use a deep well socket with a big window cut in it tack welded to a c clamp for the dual valve springs on the Chinese 110's. I also use the same tool for my Kawasaki kz750.
KartFab
Search for "valve keeper remover and installer tool" you will see the actual tool you need.
Go to autozone/oreiley,/any autoparts store and ask if they do the free tool rental (autozone does it for sure I know) you basically pay for the tool, take it home, use it, and as along as you return it to them within a month, they refund your payment so its like a free rental.
Or you can be lazy like me and get your wife to put the keepers in while you push on the springs with both thumbs.
FreeRunner15
LOL
LOL! Ain't THAT the truth.
Valve spring compressor isn't needed for 26 pound springs. Not even for 36 pounders. Just put your weight in to it. It'll get on there. Sorry 'bout your thumbs though hahahaha/
Maybe. That's not what the reciept says. Check it...you can only keep it 48 hours. (at least at ORiellys.)
LOL
A pencil in your mouth doing this??? I'm getting images of that going wrong and the pencil getting sprung down your throat.
We've had upwards of 3 days without issue. Of course my dad and I are regulars at O'Riley's, so that could be why.
Could try a pair of pliers with tape to not chew up the springs and use your weight that way.
rickou812
I'm glad to see I am not the only one that sees this as a challenge...lol
I don't think it would be that big of deal if you had a extra set of hands. I can compress the spring, as mentioned, using my thumbs, but then I have run out of appendages that can place them little bitty f'n keepers in there. I can always get one to go, but the second...nope and of course I finally managed to shoot one across the shop to no telling where!!!:mad2:
I did cut a window in a deep well socket yesterday. I think it will do the trick...but now I have to wait for another set of keepers :oops:
I don't recommend it, but after 4 hrs I was getting desperate.:roflol:
I'll find the video of the tool this guy made.
He's got a bunch of videos.
I like them, he seems like he was learning as he went.
https://m.youtube.com/watch?v=13NssmZJi00
---------- Post added at 01:42 PM ---------- Previous post was at 01:38 PM ----------
After you get the first one in, rock the spring so you can wedge the tip of the other into the place where you want it.
Do this with the head on a table or bench with something supporting the valve from the chamber side.
Rag, stack of washers,...??? I used a towel??
Then press with the end of 13mm box wrench. Press hard and wiggle. Both hands on the wrench. Use the angle to get the leverage.
Then press harder and wiggle some more.
Then let up.
Sometimes it falls into the right spot.
Sometimes it falls in too deep.
Sometimes the sob flies cross the room.
Find it and repeat.
rickou812
Then let up.
Find it and repeat.
Well there ya go. I think I will copy his proprietary tool :wai:.
Got to love his accent...reminds of the guy on the minions movie..lol
Kentucky Boy
Bowling Green, KY
Put your spring in a vice, compress some, apply a few zip ties to keep it compressed. Instal, have someone keep the keepers in position or use assembly lube. Cut zip ties off the spring and don't get pinched.
