Help on if throttle should be changed
Harmon IV
GC 160 Honda 5 HP off a power washer
I've searched for my answer but haven't see a set up like I have.
I've read they run wide open once they start. I'm wondering what I need to do to make my throttle work. I got everything ready to go except my throttle.
Harmon IV
If I remove all that Do I need anything extra to hook up my throttle other than a return spring and throttle cable?
mindymogul
Mistress of Destruction
Land of Camo and Fireball
The one off my Cub Cadet rototiller is the same way. What I did was make a lil' bracket (Stole one off a mountain bike) to hold the throttle cable in place with the valve cover bolt. You'll have to get a throttle cable with the S hook on it (Or get a S hook and loop/crimp the wire to it. You'll want to keep the return spring and mount it someplace. And detach the governor rod. You should be set.
Rail rider
Inmate # 3192016
Planet earth ( the flat one)
Can't remember where, but I know I did see someone a different throttle arm on a GC engine to make it usable.
