I'd suggest a puller. You can probably rent one from autozone or something if you don't want to buy one.
You might try spraying really good with the best penetrating oil that you can get your hands on and tapping on it with a hammer for a bit to try and work the lube in and shock the rust loose. It may not work, but then again it might.
I love the brute force ... You ARE coming off there. NOT PLAYING THAT GAME TODAY attitude.I take them apart then cut a slice in it where the keyway is with a cut off wheel.. Then I spread it a little with a chisel and it slides right off.
what's tour weapon of choice ? SAWZALLI take them apart then cut a slice in it where the keyway is with a cut off wheel.. Then I spread it a little with a chisel and it slides right off.
Can you push it back on father towards the engine. Clean the shaft and lube it then pull the clutch. I had one held on with a c-clip and it was deformed had to file the edge down to get the clutch off.
Mrc.
This is what I use.
This is actually something a lot of folks overlook. SERIOUSLY! If you can move something back a 1/16 th, then forward an 1/8, a little back and forth gains a little each time.
Too many times ( especially when it's so hard to get that first budge)....people don't want to go back the other way.
But it's the quickest way! 1/16 becomes an 1/8 th, which becomes a 1/4", ect....
Each time you do it, it removes a touch of rust, and allows more penetrating oil in from both sides.
