Need help with predator 212 kill switch. Pls pls
Brandonevan22
Does anyone know if i have to have a actual switch or can i just have a wire hooked up and then a wire connected to the frame. And touch the tips together to turn it off?
You can get a cheap switch for this application at any radio shack, Home Depot, and other industrial supply....
You need to fill in your location... So we could recommend another source...
Having a wire flapping about doesn't seem like a good idea... As it could shut off at any moment cause it touched ground...
If anything, one could mostlikely rig a wall switch to use in all frugalness.... But why... ~$5 isn't that much...
Brandonevan22
Sorry i thuaght i posted it to the same thread. Im new to the website. Does anyone know about go kart tires well?
Brandonevan22
Sorry the tire guy took the day off.. It's just the fab, clutch, engine, electric paint and upholstery department open today .. Tires will reopen Mon at 8am
Lol thats funny
---------- Post added at 08:53 PM ---------- Previous post was at 08:51 PM ----------
Thank you All i figured it out!! Ill post some picks of my build tommorow. The only thing i need is a kill switch and a seat. Thanks to everyone that helped!!!
Bbqjoe
Banned
Location, Location
Lol thats funny
Well the tire guy made a brief Saturday visit.
He will really only tell you one thing, and that's not to buy Harbor Freight tires.
Oh, God. You didn't buy HF tires did you???
Brandonevan22
No i didnt lol i bought a replacement tire tube that was 15 by 6 by 5 and my tire was only 15 by 5 by five. So i was going to ask if it would still work. But i put it in there anyways. Ill be fine.
---------- Post added at 11:37 PM ---------- Previous post was at 11:22 PM ----------
Ok so have a question about a light and battery set up.
So if i wanted to hook up some tail lights and headlights with a battery. How can i install them and is there any way to make the predator recharge the battery? I know it sounds like a dumb question but any help will be appreciated.
Believe it or not, that question has already been asked several times over. In fact I challenge you to ask a question that hasn't been asked before. :D
The Search function will be your best friend.
Rail rider
Inmate # 3192016
Planet earth ( the flat one)
How do I set up my electric kart to run off of a thorium reactor ? BOOM AND DONE !!! I guarantee that has never been asked .
Thorium sparklers?????......
Something tells me if you are near thorium, and its sparkling........ Your body might be also.....
Here is a good way.
http://www.diygokarts.com/vb/showthread.php?t=23757
Another thing is to get a Cheapo Cordless 12 Volt Drill from Harbor Freight and use that battery and charging system.
I think it is possible to change out the Flywheel and stator. But that is more complicated and expensive. Also unproven around this forum on the 212 engine.
