Stuck Valve?
qtband
St. Louis, MO
Stuck Valve No More!
This Honda 9hp has been sitting for 6 years. The carb was full of rust as was the gas tank. I bought a new carb ($15) and had a new tank. The engine spun over pretty easily so I checked the compression. There was none. I took off the valve cover and I think I have a stuck valve. The right rocker arm moves up & down but the valve doesn't look like it's moving. Is there an easy way to fix this?
http://www.youtube.com/watch?v=B91jzIe32Uo
Ummmm ....wait...WHAT???? The rocker moves up and down but the valve doesn't???
Where's my Excedrin? Wait WHAT? How does a rocker move and a valve NOT?
I posted before I viewed the video; here's the problem: there is NO way that healthy cam , tappets , and pushrods can do what I see in that video!
The only appreciable slack in that scenario is valve lash. I see a slight movement of the valve spring. That can ONLY happen if the valve moves!
Something is wrong down below!
My two cents.
Flyinhillbilly
The great cornholio
North West Arkansas
When we ran the maple syrup for oil it glued the valves open once it cooled off. We cleaned it up and it ran good again. FYI, beer for oil don't fly.
qtband
St. Louis, MO
I'll take the head off tomorrow and do some investigating! Where is my magnifying glass???
Randy H
The old timers always used to say soak it in cider. If she won't consent to that. Use your favorite penetration oil. Get the rocker arm out of the way, make sure your piston is out of the way. Gently tap the top of the valve with a brass hammer or wood block. Once the penetrating oil works is magic, via capillary action, all it should take is a little percussive maintenance with the appropriate device.
Flyinhillbilly
The great cornholio
North West Arkansas
The old timers always used to say soak it in cider. If she won't consent to that. Use your favorite penetration oil. Exhaust valve? Remove the exhaust and put a little pressure on the valve, a strong finger might do the trick. Get the rocker arm out of the way, make sure your piston is out of the way. Gently tap the top of the valve with a brass hammer or wood block. Once the penetrating oil works is magic, via capillary action, all it should take is a little percussive maintenance with the appropriate device.
While I agree that this will most likely get the valve moving, I'm afraid that any rust or corrosion (what's probably holding the valve open) would eat up the guide in short order resulting in poor valve seal and oil burning.
Randy H
You're probably right. But it could be just a little varnish too.
You quoted me just before I edited. Ignore my malarkey about pushing on the valve.
Flyinhillbilly
The great cornholio
North West Arkansas
You're likely right about it being varnish since it looks pretty good under the valve cover, but I personally wouldn't chance it. I'm all about 100000000rpm on stock stuff though. Go figure.
qtband
St. Louis, MO
Not Stuck Anymore
I slid the rocker over and gently tapped the valve. It released rather easily after 3 taps. I rotated the engine and everything moved as it should.
I installed the new carb, plug and tank and gave it a pull. I only get a second or two of running and that is with full choke. One time (and only one time) I had it running at high rpm's but as soon as I let go of the throttle it died.
So, tomorrow I will take the carb off of another GX270 that works perfect and put it on this engine. If it runs OK, then I have a bad "new" carb.
Here's a video of the start situation:
https://youtu.be/dLRo9t5QwqQ
Also some pics....
Randy H
Good for you. Now the next time I have that problem it'll take a 50 ton press to get the valve free.
Rail rider
Inmate # 3192016
Planet earth ( the flat one)
Also some pics....
I bet that valve is stuck open again.
qtband
St. Louis, MO
When I put the other carb on it, I had the same problem so that told me there was another issue. I checked the valves and they were working properly. I did notice that the gasket between the insulator and the engine didn't appear to be sealing right. It was new, but I replaced it with one I made. I put it all together and it started and ran on the first pull! Next issue, it smokes pretty bad. When the weather warms up, I'll put it outside and let it run. The rings may have to "loosen up" after sitting for 6 years. If not, looks like I'll re-ring it.
Randy H
You've probably already done this.
Get the piston at TDC. Spray in the spark plug hole your favorite penetrating oil, atf maybe. Lightly screw your plug in place. Let it be for a while. When you're ready to try again remove the plug, place a rag over the plug hole and give a few pulls. No reason to build up more gunk in your engine. With any luck that and some run time she'll be a runner, probably always a smoker though.
If you have to rering it. Since it runs you could try what we (my circle of rednecks) call a Mexican tuneup. Using a spray bottle of water, with the engine at moderate RPM give a shot (multiple shots) of water down the carb throat. Saves a bunch of cleaning.
qtband
St. Louis, MO
What will that do, exactly?
FHB and Randy, Please correct me if I am wrong.
I always thought that since water does not combust or Mainly in this case since it does not "compress. The non compressable water actually blasts the excess carbon off the piston and combustion Chamber.
Correct???
Correct???
Nope! It steam cleans the combustion chamber and blasts the carbon right off. You could mix in a little Bon-Ami or Commet scouring powder and reseat the rings too. :thumbsup:
Randy H
Steam clean sounds right. Not your average steam though. Like high pressure steam. Scary stuff. I first noticed the phenomena on a 75 Impala with a blown head gasket.
I wasn't gonna bring up the Bon Ami, Comet. Old timers spoke of it. I think I read about it in a manual. Really for new rings that won't seat in old diesel engines.
For experimental purposes only, if a guy wanted to try this in a gas engine. Make a slurry with your abrasive of choice and water. Put just the right amount in the spark plug hole. Fire it up and let the fun begin. By fun I mean total engine destruction.
