Cyclone Flower Vase / Incense holder
The closest thing I could find to a vaporizing bowl was a brass garden hose cap, so we'll go with that. :thumbsup:
I drilled a hole in it, inserted the brass screw & snugged it down with a brass nut.
pic 2 has a zinc screw next to the brass screw for contrast.
pic 3 shows our vaporization bowl on one with double inhalation tubes.
Rail rider
Inmate # 3192016
Planet earth ( the flat one)
How about a 3/4 or 1 in copper pipe cap (sweat fitting) you can cut it down if needed . We cook with Copper it's gotta be a lot better then brass. And a stainless steel machine screw.
I've always heard copper releases BAD fumes.
Since your post I did a little research. :thumbsup:
It seems that when cooking with copper, the body's liver filters out the toxins but, when directly inhaling/smokin' out of it your lungs don't have the same filtering capacity.
The Graffix piece I used as a model also used a brass bowl & brass screw so, I used a brass bowl & a brass screw.
...& since most metal pipes are made out of brass or chrome plated brass, it kinda gave it some validation. for me.
I also found:
Vaporizers make the psychoactive components of cannabis airborne and inhalable, without burning the plant matter and creating smoke.
The vaporization process allows one to avoid the production of toxic and irritating smoke, because the temperature that it heats the cannabis flowers to is just high enough to boil off and vaporize the active cannabinoids without causing the combustion of the plant material, so there is no smoke, or very little smoke.
Bbqjoe
Banned
Location, Location
Dam, I thought we were talking incense.
I tried cannabis once, it made me want to rape and kill, and I was addicted immediately.
Before I knew it, I was robbing gas stations to get my next fix. :D
It is incense, if you leave the top off & just let it freshen the room. :thumbsup:
---------- Post added at 10:10 AM ---------- Previous post was at 10:00 AM ----------
Really!? :ack2:
NOT FUNNY! :mad: People still believe that stupid :censored:.
---------- Post added at 10:23 AM ---------- Previous post was at 10:10 AM ----------
Drugs are really bad!
Thanks for dropping that bombshell of knowledge on us.
Which drugs? Opiates, barbiturates, cocaine, heroine, the flu shot?
Everything is bad for some folks or even in excess.
(Sun exposure, sugar, sex, gambling, even water)
I believe that Cannabis can genuinely help many people.
Whether it helps a chemotherapy patient deal with nausea & getting rest, helps reduce epileptic seizures or just keeps someone from kickin' their dog after a long day,
...it helps. :2guns:
Finished up the third DIY vaporizer today.
Donated one, to a local cannabis club/wellness center, :thumbsup:
...one, to a friend that lost his left arm in a truck driving accident :2guns:
...third one, is for testing purposes (research & development) :cornut:
https://www.youtube.com/watch?v=3V0YgOjfEcY&t=12s
1st pic is of the original brass bowl & screw from the old Graffix unit & soldering iron end piece.
Bbqjoe
Banned
Location, Location
It drops the voltage.
---------- Post added at 09:18 PM ---------- Previous post was at 09:17 PM ----------
There fore less voltage through the same resistance will make less amperage used. Less heat.
