Wet Clutch
qtband
St. Louis, MO
I just purchased a BIG concession kart that has a 9hp Honda and a wet clutch on it. The kart sat for 6 years so I'm going to replace the carb and tank but I have a question about the wet clutch. Do i need to drain it, clean it or what? I never had a kart with one. Here's a pic because everyone wants a pic...
Staff Murderator
I just purchased a BIG concession kart...
What kind of snacks does it make?
qtband
St. Louis, MO
Here is a picture of the wet clutch. Is there anything I should do to refresh it?
Those reduction/clutch boxes are pretty much dont need maintenance... but since it was a ride kart... If anything an oil change will help....
Im sure there is someone who knows more, will chime in shortly....
B_Bimmer
That looks like it is designed to run FOREVER. How much did it set you back? Very neat.
B_Bimmer
That's not even fair. That's an awesome toy for $140, I'd say you"ve got some spending money left over.
Twisted
ON, Canada
If I were you I would change it, the drain plug is on the backside down by the frame. I just use 10w30 motorcycle oil, it works pretty good. These clutches are basically industructable just dont rev them past 7000 rpm. Also on the dipstick there should be a tiny hole make sure its not plugged as its a check valve to release pressure
gokartdaddy
MARYLAND
i have one i never used. it came on an old gx140 i got off Craigslist. Would it be good for performance for a cart ? and how do you gear it .
Twisted
ON, Canada
They can handle quite a bit of power, but they also rob alot on smaller engines. For a preformance kart I honestley would go with a different setup. As for gearing, I currently run a 28tooth upfront and I believe 70 in the rear but its a cogged belt, these clutches are also a 2:1 reduction ratio. Also if you want to run these clutches you will need a rh2x crank so a predator motor wont work because they are 3/4 cranks and the clutches i/d is 20 or 21 mm.
