Torque converter
Massy135
I need a torque converter for my go kart it's got a gx390 13hp Honda engine what torque converter do I need
the GPS IS a knockoff as well!
it just comes with a backplate and a reverse wound spring..
but yes.. a series 40 (personally I'd get one off ebay tbh) is what you want!
that is if you indeed have a 1" straight shaft, no taper nor splines!
else (say you got the engine from a generator or pressure washer)
you likely need to get a new crankshaft as well and buying a TC is the least of your problems :(
Joe-405
Enjoying New Projects
U.S.A.
Mine was all stamped Comet on mine when I had it.
Randy H
The price sure is good on the 40 series. This spring I'm going to try a 94c or a 780 series. The 40 series has about 2.5:1 reduction. The others are closer to 3.5:1, I believe, and $200-300 more. Seems like a good performance gain though. Something to ponder. Especially if you don't care to tear a Predator apart. Also assuming it would even fit the intended chassis without a lit of grief.
Oh cool...
depicted on the website is a clone though.
And since nothing on the ad says it's indeed a genuine comet;
I doubt you could pin them down if they send you a clone.
Joe-405
U.S.A.
Oh cool...
Correct. And I know I got one of the first ones which coulda had something to do with it also.
supermanotorious
Winchmaster 5000
New River, AZ
40 series would be best, but depending on your needs and usage, you may be able to skate with a 30 series and save some dough, I have tutorials on this site how to make the 30 series fit the larger engines
