Valve Float
Randy H
Power loss. Potentially major engine damage. On the bright side, it may prevent a broken rod.
I've tried to look this up on the YouTube... No go... Talk about yes... But no actual vids showing this phenomena on a clone type motor... Of course small chevy ya sure... No small engines...
qtband
St. Louis, MO
The reason I ask is because I think the 301 should be revving higher. I have a Step 1 performance kit on it. A filter, jet, header and governor removed. When I get to a certain RPM, it just levels out. Almost like the governor was still on it.
Yeah....well, that's valve float. Get stronger springs and it wont happen. The engine will rev much higher, the rod will pull a Snaglepuss...and "Exit...stage left...." right through the block. Then ... NO MORE VALVE FLOAT!
Well yeah, it will blow up with only stronger valve springs.
But if you add a Billet rod it will stay together. and an adjustable or 8° timing key on the flywheel.
and many/most suggest a Billet flywheel too... But no-one can seem to find a broken stock
flywheel due to hi revs either.
Wanna go fast? $$$$$$$
qtband
St. Louis, MO
So far, I haven't found much beyond the stage 1 performance kit for the 301. I may just leave it since it's still a blast to ride.
