14 cc hemi head
matiask1
Santiago,chile
Hello
Currently im building a racing engine and I want to change the head and I have this question how do I fit a 14cc head to a predator hemi engine and where can I buy that head??? im going to use 97 oct fuel thanks:cheers2:
For you its probably going to be eBay or were ever that will ship to you...
Or a lawnmower shop of the like...
KartFab
So how I get to a 12 to 1 compression
Math:
Given
Bore
Stroke
Piston top height in relation to top of block at TDC
Head gasket compressed thickness
Head gasket diameter
Head volume
Find
Static compression ratio
If too high, get a thicker head gasket or mill piston
If too low, you could get a thinner head gasket, deck block, or mill the head.
That's the dumbed down version. Hope it helps.
On my hemi I used 0.027" head gasket.
Milled the head 0.037". (18cc)
+0.020" connecting rod to put my piston 0.004" in the hole
Stock flattop piston.
Black Mamba Jr Camshaft 0.276" lift
11.1 :1
A similar set up with a 14cc chamber and stock 0.045" head gasket will give you 12:1.
You can get 14cc by milling the 22cc Hemi head or just find a gx160 head. If you get the gx160 head, I'd port the ports bigger.
If you mill the Hemi Head (already has bigger valves and ports) I'd try around 0.050".
https://gokartmods.com/gx200-modifications/
---------- Post added at 02:11 PM ---------- Previous post was at 02:09 PM ----------
What camshaft. You cannot mill too much so that valves will hit piston, you cannot get a gasket too thin where the piston hits the cylinder head. 0.050" or more between the valves and the piston. 0.020" or more between the piston and cylinder head.
