Racing predator break in
matiask1
Santiago,chile
Hello,
I have a 212 predator hemi with performance carb rod flywheel and more but I had never started it so what break in do you recommend time, oil, revs thanks.
Bbqjoe
Banned
Location, Location
Hello,
I have a 212 predator hemi with performance carb rod flywheel and more but I had never started it so what break in do you recomend time, oil, revs thanks.
There's a nifty little brochure that came with your engine.
I'd follow the suggestions there.
I suppose you could always speed up the break in by running it a short time without oil.
PredatorPowaaa!!
Mistake Maker
Ontario,Canada
fill it up with oil, and then gas, and let it idle for like 45-60 minutes. when the time is up, stop the engine, empty the oil, and refill it with some brand new oil. bada bing bada boom. and by brosure he meant the instruction manual. (i think)
Joe-405
Enjoying New Projects
U.S.A.
No ethanol fuel and a high zinc oil is what I use.
Ex. Royal purple break in oil.
Staff Murderator
Some break-in procedures from around the interwebz:
2.0 Break-in procedure
The importance of properly breaking in an engine is to allow heat stresses from the manufacturing process to be relieved and for proper ring seating.
We do not recommend the use of synthetic oils for break-in as in rare cases the enhanced lubricity and friction modifiers could prevent proper ring break-in.
After properly installing the engine:
➊ Add 14 ounces of a high quality 30 weight automotive oil. Only during break-in do we recommend the use of automotive oil. Never at any point in the life of your engine do we recommend the use of ‘karting’ oils. These products use base materials that have severe limitations and offer very limited protection over time.
➋ Assuming that you can break your engine in on the race track proceed to put 10 minutes of varying rpm on the engine.
✲ You are not racing at this point and simply allowing a slow progression of increasing the rpm and range during break-in.
➌ After 10 minutes of slow track break-in shut off the engine allowing it to cool somewhat.
➍ Repeat with another 10 minutes or so of varying rpm on the track.
➎ At this point, with your engine shut off drain the oil while it is still warm.
✲ Note: your oil will be over 200 degrees and care must be taken.
✲ The reason behind changing the oil while warm is asperities from the break-in process will still be suspended in the oil.
➏ Again adding 14 ounces of oil repeat this cycle.
➐ After 2 additional track sessions of slowly increasing the rpm and range, your oil should be changed out once again while warm.
This concludes the break-in procedure.
New Engine Run in procedures
When it comes to the first-time fire up of a new Briggs & Stratton racing engine there are no overly complicated procedures to follow during the break-in period. There are a few very important things that you should follow and understand. The Briggs & Stratton side valve, Raptor, Briggs & Stratton Animal, Local 206, Junior 206 and Briggs & Stratton World Formula engines are air-cooled engines and use a splash-feed oiling system. With newer technologies on engine components like pistons, ring, bearings, con rods, crankshafts and new technologies used in engine manufacturing processes and modern synthetic oils, long run-in (break-in) procedures are a thing of the past.
A bit of care and preparation can make the experience of starting your new Briggs & Stratton racing engine fun as that is the reason most of us get involved with these little rocket ships. Once every thing is fitted up, have a quick check to see everything is intact with nothing loose and all nuts and bolts are tight. It is a good idea to get the fuel line from the tank to the intake side of the fuel pump so you are not winding the engine over too many times before it gets fuel to the carb. Remember the Briggs Intek racing engines fitted with the Walbro PZ22 & PZ28 have chokes and they should be utilized for all cold starts.
Briggs Racing Engine Stage 1 Run-in procedure
Fill new engine with Redline RL157 4 stroke karting oil. Run for 10 minutes with no load at around 2000 RPM, Try not to let the engine idle as it is important with a splash feed engine keeping the revs up above idle will get the oil slinging and splashing over the moving parts, cylinder walls and valve train area. Run Your Briggs & Stratton Racing Engine for 10 minutes. If you need to make any adjustments switch the engine off, do what needs to be done, have a quick look at the oil level through the filler plug then restart and continue the first break-in period. After this first stage, let the engine sit for 5 minutes to let the oil return from the top end of the engine. Then while the engine oil is still warm drain the oil. This first drain should remove any particles from the cylinder walls, rings and bearing material that had been created from the rotating components of your engine's first run.
Briggs Racing Engine Stage 2 Run-in procedure
Refill Your Briggs & Stratton Racing Engine with Redline RL157 4 stroke go kart synthetic oil. It will take 600ml to refill the crank case. Check for leaks or any loose fasteners on the engine. Once the checks are done restart your engine and load the engine for 15 minutes; the best place to do this is on the race track. During the 15 minutes of run time, vary the engine speed. It is advised to keep your engine below 5000 RPM. By keeping the engine loaded it will bed-in the piston rings to the cylinder bore. After you have done about 15 minutes of driving time, it's time for another oil change. Let the engine sit for several minutes, drain the crank case and refill the engine with another 600ml of Red Line RL157 4 stroke synthetic go kart oil.
Briggs Racing Engine Stage 3 Run-in procedure
Once your engine is refilled your engine is ready to be used for its intended purpose. After a warm up start and a quick check for any leaks, your racing engine is now ready to be run at racing RPMs. Your engine will be happy to run up to 6500 RPM. Oil changes are something that should receive careful consideration. An engine running at high RPM that has an oil capacity of 600 ML should be changed regularly. To get the best out of your engine wear-wise this method has been used here in Australia by People Running OHV Briggs & Stratton MotorSport racing engines that at the time this info was compiled changed their Redline Racing oil after every meeting. A regular race meeting consists of 3 x 8 lap heats and a 12 lap final. That is about 36 laps running most of the time at full noise around 5700 RPM. Animal Racing Engines using this formula have over 100 race hours on them and most of those hours are at race speeds and high revs. The Briggs & Stratton Animals are still running strong.
Thanks for this useful info.
I just broke in my engine today, and this was helpful.
Keystone Motorsports
But who was phone?
Lebanon, PA
What I have done on mine is follow break-in procedure as the manual states BEFORE doing any sort of mods. That way if something is faulty I can take it back. Afterwards I drain it, mod it, and then do another short break in (namely for tuning) and away I go. I haven't done any sort of extensive mods (like conrod, flywheel, etc) so I cant comment on that aspect but if I were to do so I would probably do another by-the-manual break-in before I do anything.
Staff Murderator
I agree with you, Keystone Motorsports.
They should all be broken-in right out of the box. Just firing it up after adding gas and oil satisfies the desire to see that it actually works (and it's not one of Rail rider's broken returns). :D
Every engine should be run-in stock and then upgraded later so the end user's seat-of-the-pants dyno can note the difference.
