how do i reinstall the clutch spring?
horror_fan
took out the clutch. before I figured out how to take the clutch off I accidently took it apart. :cheers2:
cant get the spring back in.
also, in the picture i took .. i was wondering if thats how the 6 roundmetal pieces are suppose to sit.
also what kind of clutch is this?
Flyinhillbilly
The great cornholio
North West Arkansas
You just have to fiddle with it until you get it together. They are a PITA, but very doable. It gets much harder to do when you start shortening the spring to get more stall out of the clutch.
There's a you tube vid out there...
I used 3 locking C-clamps to hold the backing plate on while I put the c-clip on..
I have a helper (wife) help hold some parts in place. While I work in other parts.
As stated they are just a pain. But you can do it.
horror_fan
i think the spring is shortened because it just doesnt stay! :furious2: ! i was messing with it for almost an hour. I learned to put two ends of the springs into one of the metal things so it forms a circle... still can get it to stay expanded though.
---------- Post added at 06:31 PM ---------- Previous post was at 06:31 PM ----------
i saw that youtube video after i made this post. lol, but not sure if im going to be able to do it.
I saw the vid... But didnt have a piece of wood...
The spring does fight you when clamping the back plate against the shoes...it wants to pop out...
I clamped one side starting with the springs ends.....worked the spring around and clamped.... Then poked slowly the last bit in with a flat screwdriver... You kinda have to gradually tighten the clamps after the first one seated...
Much easier typed than done...
Or get a Hillard with C springs and call it a day.
Ok Wait
I have an idea. Duh!
Call Mike at IMI Auctions 303 833 0491.
He has clutches for $17.53 free Shipping.
Price varies a buck or two.
Done! and well worth 20 bucks an hour of frustrating labor! I ordered one last month and had it in 2 days.
most importanlty: start with the hooked section in the center of a weight.
it helps to keep the weights together (say resting in the clutch bell as shown in the video)
but you can take just about any round container that fits ;)
(or some rubber bands if you like)
still a huge PITA but doable!
just use one hand to hold the spring down in the weight (for five weights that should be doable with one hand, right ;))
and as soon as the last weight has the spring seated it shouldn't pop back out anyways.
horror_fan
well regardless of it being a PITA, I have no other choice if I want to drive the go kart...and im not going to buy another clutch when i have a perfectly good one.
Thanks! I did suggest it. But I admire you DIY Attitude.
So keep at it! It is possible.
Here ya go I finally found my pics from years ago....
This is how I clamped it together...
