Flyinhillbilly
The great cornholio
I've mostly done roll cages and off road bumpers. I do my bends by myself, a minibike or go kart frame should be butter in one of those. Another plus is that I'm always a beast when I finish a roll cage.
But Isnt minimun wage alot higher there?
I've had my bender for a minute, (wouldn't fit under the gate) but It was ~$59.00 when I got it.
Why is that relevant? If something is worth $X, it's worth $X, no matter how much money people earn...
The bigger issue would be the exchange rate; for example, the price in the one linked by FA converts to $397AUD...
You do have some stuff we don't have, like 302 clevelands and the turbo in line six Ford falcons.
Not sure if shipping matters but if one of us ordered something and shipped it to you would it be cheaper.
Biggest trick I learned using the JD bender , don't use eyeball to keep bends level with each other on hoops. Level the bender off the main die pin then use level on tube after first bend , an accurate digital level is a big plus compared to the angle guages with needle
The only flaw in that advice is allowing for spring back...
Any time you bend any type/shape metal, you need to allow a few degrees extra because, once the pressure is relieved off the bend, the metal will relieve as well, springing back a few degrees...
Some machines are calibrated to allow for spring back but, not all...
Bye guys! It's been fun.
+neWhat, are you going to join the band?
