Comet TAV2 Gear ratio
PredatorPowaaa!!
Mistake Maker
Ontario,Canada
so i'll make this short. i have 22'' (ish) tires, 10 tooth on the TC, and 60 tooth on the axel. the buggy weighs maybe 150 pounds, and i weigh 85. is this ratio correct?
If it were me I'd put an 8T on TC.
More Torque = More Fun
But if the TC came with the 10T, try it out.
Should do over 40mph at 3600 RPM.
The stock sprocket on the TC Jackshaft needs a separate key. The 8T I got had the key built in.
I cut the stock key a bit shorter. No biggie
I think I had to grind one end of the sprocket to make it fit how I wanted, but nothing major.
Again, NO Biggie.
PredatorPowaaa!!
Mistake Maker
Ontario,Canada
comet TAV2 question
i just had a quick question, so my torque converter get pretty hot. hot enough that you wouldent want to hold your finger on the drive clutch for more than half a seccond. i was wondering if 1: this is normal 2: how to keep it cool. has anyone ever put like a fan on thiers or somthing?
same thing!
your TC is overheating because of slip.. because your gear ratio is off..
thus: MERGED!
PS IF the weights you assumed are correct (I doubt they are but let's assume they are...)
you'll need a 7:1 ratio to keep your TC alive... that'S either a 70T axle sprocket or a 8T TC sprocket (7.5:1)
(be aware that the tight radius of a 8T sprocket will cause premature sprocket wear... indeed 20% faster than a 10T ;))
How'd you get a Predator in Canada, Aye?
Are you running with a governor?
Are you running stock valve springs?
Switching from a 8T to a 10T increased my max speed about 10%. I went from 48 mph to 53 mph.
My max RPM dropped from 7000 RPM to 6300 RPM.
It kinda depends if it is the governor, the valve springs, the camshaft, or the gearing that is limiting engine RPMs.
PredatorPowaaa!!
Mistake Maker
Ontario,Canada
well, to be honest, its not actually a predator, its a princess auto 208cc engine that is basicly the exact same thing as the predator. its just easier to say predator than to say "princess auto 208cc honda clone" if you know what i mean. no i do not have a governor, and i am still running with stock valve springs.
---------- Post added at 10:42 AM ---------- Previous post was at 09:59 AM ----------
so you are saying that i will go faster?
No... its not really the same..... there is a number of distinct differences then the 212....even the Champion 208 has got its differences aswell.....
Since there is a number of us Canadians here... Easy enough to call it a princess 208cc..... I do... have one on my other bike....
Call it what it is not what it isnt.......
no i do not have a governor, and i am still running with stock valve springs.so you are saying that i will go faster?
Your stock camshaft and large tire size will limit your engine RPMs below 5400 (valve float), but the new gearing with 8T will allow the engine to rev higher than it would with the 10T.
If you were at Max 3600 RPM and Max 44 MPH with the 10T.....
With the 8T, I'd expect Max 4000 RPM and Max 39 MPH.
That is just an example. I'd expect a near 10% increase in Max RPM and a near 10% decrease in Max Speed.
For me, top end is boring. I don't race. Bring the Toque, Bring the Fun. I switched from 10T to 8T on the buggy and like it more. I switched from 8T to 10T on the minibike and liked it less.
Moral of the story, you will go slower with the 8T, but will not miss the 3-5 MPH loss on the top end.
