HF Predator Engine 212cc slow...
jtrem
My boss had given me a road rat Akra Racing Kart a few weeks ago. Originally it had one of the old motors that was sold at HF the Liftin 6.5hp. but it was shot.
I replaced it this past weekend with the 212cc from HF. Since getting it hooked up and going ive noticed its slow as crap. It will eventually pick up some speed, but off the line its a turtle. The linkage looks to be all adjusted properly.
I know the motor has a governor. Does that make that big of a difference?
Any help would be appreciated. Large combustion engines I am great at. The small ones not so much.
Sounds like a gearing issue.
Governor only limits High RPMs. So that would be top speed not off the line.
How it is Geared. Sprocket tooth Count on Clutch and Axle. Should be Like 6:1
Axle Divided by Clutch.
Was the Lifan a dog too.
jtrem
18t on the clutch and 59T on the rear sprocket with a #35 chain set up.
No clue on the old motor when i got the kart it was blown.
---------- Post added at 08:05 PM ---------- Previous post was at 08:04 PM ----------
possibility the chain is has too much tension? Not sure how much slack it needs.
Well, there's your problem; 3.2:1 gearing is WAAAAAY too low; ditch that gear, get yourself a 12t clutch & 60-72t axle sprocket, depending on the height of the rear tyres
It's possible but, it has nothing to do with the above issue; a correctly tensioned chain should deflect the height of the chain in each direction...
jtrem
Chance maybe the clutch is bad? Just talked to my Boss and he said it moved pretty decently when he had the liften motor in it. Makes me think maybe the clutch is bad causing it to bog down.
Nope It is the gear ratio. Well probably the clutch too. Like I said should be around 6:1. 72 and 12
You have 18 and 59. 3.2:1. It burns up the Clutch.
What it amounts to For example. If you were driving a Stick shift car and trying to Take off in 4th gear. Even with a big engine, You know what that would be like... You would smoke the clutch.
You could get away with 5:1, Depending on tire height. That way you could keep the 59 tooth axle and just buy a 12 tooth clutch, 20 Bucks on ebay. You will be good to go.
jtrem
Just bought the 12 tooth clutch of ebay. Ill let you know when it gets here and I swap it out! Thanks for all the help thus far.
Staff Murderator
Here we are basking in the glory of our 21st century technology--photos can be sent across the airwaves and we have video phones.
But hardly anyone ever submits a photo.
I just hope the chain and tooth pitch is correct on the newly purchased clutch.
I forgot to mention that last night. There are two common sizes. #35 and #40
Jfive
Great falls Montana
Maybe there like USA auto company's and they want parts sales. It does seam kinda weird that a go kart company would have the ratio like this.
Well in racing, I guess they are hoping you can keep it pinned at 45mph and only need to accelerate once?????????????????
Staff Murderator
Hey New guy, problems with your gear ratio notwithstanding, these engines are industrial engines--designed to putter along happily at their maximum designed RPM (3,600) or somewhere in between their entire life, powering lawnmowers, pressure washers, roto-tillers and the like until old age and lost compression, neglect and/or a myriad of other ailments sends them to the scrap pile.
They don't approach higher speeds without a little 'massaging' from the end-user...
You calling it "slow as crap" is kind of a compliment. :D
jtrem
Thanks for all the info guys and yes I got the correct clutch. #35 for my application.
Hopefully this new clutch works well and doesnt blow out quicky.
I have two of these karts the other one also needs a new engine and fuel pump. So we will see how this one goes before I dive into the other one.
