Hello everyone
Leonard swinehart
Hi guys I have a very important question I just bought a 200cc Lifan engine what is the proper mounting degrees for the engine I have looked and looked and I cannot find it nowhere if anyone knows please message me back thanks guys
First, I don't see much of an intro there so, thread moved to engine section...
Second, I have seen many different designs of Lifan engines; to which one are you referring?
:useless:
Leonard swinehart
Pictures
Hey guys sorry I cannot download pictures I've tried 2 or 3 times it keeps telling me invalid file but it's just a regular 200cc Lifan engine Kickstart and electric start 428 sprocket on the motor 30 millimeter carburetor I believe I am at work right now but when I get home I can write down the numbers of them that's on the motor and put them on here if that would help
---------- Post added at 09:09 AM ---------- Previous post was at 09:08 AM ----------
I know it has to be mounted to some degree because the oil does not show up and the eye glass but when I leave the motor forward a little bit it does just trying to find the proper degree
Bwdeaton
Dayton, Ohio
The carburetor should be level to the ground. I'm not sure what the tilt degree is on the engine, but if it has a carb on it then make the carb level with the ground and it should work fine.
Bbqjoe
Banned
Location, Location
I used to stay at home and believe I was at work. On Friday's I'd show up believing I'd get a paycheck.
Alas, this was never the case. :rolleyes:
I woke up on a Saturday morning after going to a bar the night before. I opened up my wallet to find all but a few dollars of my paycheck gone. After I recovered from the heart attack...and woke up a little more...I opened my dresser drawer where all that money was.
Good advice for going to bars or gambling joints...take all but a little bit of your money out and put it away before you leave the house. Not only does it protect you against pickpockets or parkinglot robbers....But it's too easy to spend more when your wallet is full of cash....than when you only have a couple of 20s and can watch it dwindle.
