420cc Torque Converter Race Kart question
420cc dirt
First want to say Hello to everyone. New guy here needing help
I have a 88 Emmick Express Sprint race kart American Rail, I have a stock420cc clone engine mounted and trying to run a TAV 30 1'' torque converter with a 12 tooth on the torque converter and 53 tooth sprocket on the axle running #35 chain. It struggles to pull me off the line WHY is this going on? its not like I don't have enough HP what gives??:censored::censored:
THANK YOU FOR ANY HELP.
the 30 series is not rated for that Much power. so the belt may be slipping.
You may need a 40 series.
420cc dirt
I can understand if it was at full throttle slipping but its on take off to about 1/2 throttle. It actually pulls fine 1/2 throttle on out, That being said I don't see the over power issue. But **** I don't know...
I was guessing. Your gear ratio is also high. But yes you do have the extra HP and "sometimes" that will overcome the high gear.
But not always.
420cc dirt
But not always.
I want to have a strong acceleration and good top end speed which is why I am geared high and running torque converter. I really thought a 420 would easily pull that ratio considering a 6.5 pulled it better. so IDK man.:mad2:
Yeah I am not sure either.
More Guys will chime in here shortly.
Dont Give up hope yet.:lolgoku:
Joe-405
Enjoying New Projects
U.S.A.
I know that tire size. Your at a 4.43 gear ratio.
Put a 10 or even a 9 tooth on the front and it will fix it. The 10 will give you a mid 5. Still off but alot better then you can go up on the rear if you have to.
420cc dirt
I am running 10'' inch slicks on the rear.
420cc dirt
I did 11". Had a few emmicks. They are good chassis. So do the front in either and I bet it fixes it.
How much speed would dropping to a 10 tooth give me?
Thank you for the help by the way.
---------- Post added at 09:22 PM ---------- Previous post was at 09:20 PM ----------
What is a No Rules Dirt Kart anyway? I was told my Emmick was.
Staff Murderator
Your post is in one of the least-visited subforums we have. We typically use this one chiefly for intros, not go kart issues.
BigMark408
BigMark408
Portland, OR
You have to trade the one off on the other. With your gearing at the moment, your acceleration will suck. Gearing high means you will have more speed, but less acceleration, so you are going in the wrong direction
This is Correct.
You will have to trade one off for the other or switch to transmission for shifter kart build. If your looking for more low end you have a couple options here as your not in the Correct series of TC for that Engine.
1. toss/Sell the 30 Series setup go with legit 40 Series or 44 Magnum Driver with symmetrical belt for increased low end torque(this is HUGE for your application)
2. Go with a MaxTorque Driven Unit or similar with HD Spring(clockable) to increase Torque to jackshaft (8.5" diameter or larger if you cab find one that will work for you)
3. go with 8 or 9 tooth on Jackshaft sprocket to drive Chain
4. swap to something like #40 chain for better torque transfer and less stretch in drive-train by using stronger chain
5. You can put larger sprocket on Axle for more torque but speed top end speed will be affected.. not sure how this will affect lap times if your able to actually ping out top speed on the straights?
6. Add some power options to your Engine for Torque such as Jetting the Carburetor, Removing Governor, high flow exhaust header and muffler, Milling the Head or using high compression head gasket, HD Valve springs, cams.. Etc...
Also how does the engine sit on the rear Frame in comparison to center-line of the 212cc that was removed? further forward? back more? this will affect the geometry of the Karts traction to weight transfer under acceleration and turns
BigMark408
BigMark408
Portland, OR
I also used a 30 series on my 420cc and it kinda worked... but enetually fried my belt and it couldnt take the power or put the right poweer to the wheels. Its also the Belt which is weaker. Once i went to the 44 Magnum setup it has been bulletproof for me. I still have that old 30 Series for 1" shaft if you want it for parts? it a paperweight for me in garage now.
KEEP IN MIND that when putting smaller sprockets on your Jackshaft that the walls start getting thin if enough torque is being put out by endgine the BAM!!! your done.. as you can see my 9 tooth could not handle the power of the modded Powerland PD420... Now Running a 12T with 13mm walls compared to the 2mm found on the 9T.
Joe-405
U.S.A.
It's a open class kart. So you better be fast. Or know how to drive. Usually you need both in that style class !
And you lose 3.5-4mph per tooth count.
Run what you brung.
So bring a lot.
25 MPH is slow for a race kart, no?
Un-stockify your 420cc.
How old is your belt?
Joe-405
U.S.A.
Run what you brung.
So bring a lot.
IF he's racing it ........... It really needs a turbo bully clutch or something similar. To be even closely competitive.
Not to hijack, but can somebody post a link to some kind of open adult class like this.
Like for a modified 212 or a modified 420.
I think I've heard of Predator Classes???
