Electric scooter conversion engine help.
MilesGC1999
rebmeM roinuJ
Yorktown, Virginia
I am trying to make my e zip 500 into a gas scooter. What engine should I use? I have been trying to find a inexpensive engine off Craigslist, but all of the people I contact have already sold the engines/ machine. I am trying to find a horizontal shaft engine and everything I need to run it for under 150 dollars. Amy ideas would be great. I will attach some pictures when I get the chance.
attached images.
Harbor Freight sells The Predator line of engines: 3HP 89 bucks, and 6.5 Hp 99 bucks.
Great engines. Add on a 20 dollar Centrifugal clutch and the proper axle gear and chain.
Bam 150 bucks.
MilesGC1999
rebmeM roinuJ
Yorktown, Virginia
Bam 150 bucks.
That was my original idea, do you know if I can just use the original sprocket?
I do not know what the original sprocket is.
My Razor Electrics used a #25 Chain.
Need more detail on the build, to really direct you towards proper sprockets and tooth counts.
---------- Post added at 05:33 PM ---------- Previous post was at 05:25 PM ----------
Height of rear tire.
Weight of scooter and driver.
Desired top speed.
Then a mini bike guy can get you a good gear selection and Ratio.
frankly.. why not slap on a tiny50cc engine and call it a day.. that's what all the gas scooters (like the one you have) use anyways... I think one can be had for less than 70
http://www.ebay.com/itm/49CC-2-STROKE-ENGINE-MOTOR-POCKET-MINI-BIKE-SCOOTER-ATV-H-EN02-/181162623778
chain sprocket throttle.. done (clutch is already in the set)
frankly a 212 is overkill for some fragile chinese scooter like that IMHO.. the 90cc predator might work.. IDK... the 50cc is what you can buy these things with anyways ;)
Thanks Sid. I had not seen the pic when I first replied.
The 50cc Does sound more Appropriate.
Scooter is a relative term.
MilesGC1999
rebmeM roinuJ
Yorktown, Virginia
Desired top speed.
Rear tire: 12 in
Weight: driver 140 lb scooter 25-30lb with the electric motor.
Top speed: 25 mph (anything higher than the stock 15mph)
---------- Post added at 09:06 PM ---------- Previous post was at 08:56 PM ----------
I would need a throttle, gas tank, and sprockets to use this engine right? Could I use the battery pocket to store a gas tank?
Where do you live?
I have a 5 HP Tecumseh, No Gov, Ported Intake Manifold, Header, Performance Air Filter / Adapter, Jetted Carb, E3 Spark Plug, Comet Torque Converter, stock connecting rod, stock valve train, stock camshaft.
I want $200 for the whole thing, but will take $150 from a member.
MilesGC1999
rebmeM roinuJ
Yorktown, Virginia
Where do you live?
I live in Yorktown Virginia.
MilesGC1999
rebmeM roinuJ
Yorktown, Virginia
Where do you live?
The torque converter is good for hilly or changing terrain right? That would be perfect for the trails near my house.
MilesGC1999
rebmeM roinuJ
Yorktown, Virginia
I think I will be getting a 79cc harbor freight engine. I am still trying to figure out if I should get a torqued converter or a centrifugal clutch. I also need to figure out if I need a new sprocket. Will a bike chain work? the chain is for my bmx but I don't have the chain box so I don't know the rating.
